03-01-2013 01:41 AM - edited 03-16-2019 04:00 PM
I just got my self a sip trunk to my ISP but i'm not able to make any outgoing calls.
My problem is that the CUCM sends <phonenumber>@<CUCMIP> but i need <phonenumber@<XXX.supertel.dk> .
Anybody who can tell me how to do this? i tried to Google but can't find anything on how to change the @domain .
03-01-2013 06:36 AM
Do you have a CUBE? If so you can build sip profile.
Chris
03-02-2013 12:33 PM
I raised similar question here https://supportforums.cisco.com/message/3869271#3869271
No one answered that it is possible with stand-alone CUCM cluster. So you need CUBE functionality implemented.
03-02-2013 12:40 PM
You can use sip normalization scripts if your CUCM supports it. What version of CUCM do you have...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
03-02-2013 03:12 PM
You can use the script,,,if your cucm supports sip normalization
M = {}
function M.outbound_INVITE(msg)
local rpi = msg:getHeader("Remote-Party-ID")
local uri = string.gsub(rpi, "192.168.10.1", "xxx.supertel.dk")
msg:modifyHeader("Remote-Party-ID", uri)
end
return M
Change the ip tp your cucm ip..
You need to go to device>device settings>sip normalization.>add new
copy and poist the script into the box
then go your sip trunk and select the script, reset the trunk and test it. I just tested it and it worked.
03-03-2013 08:39 AM
It is 7.1.5 version so SIP normalization is not available as i understand.
03-04-2013 05:08 AM
Alexey,
No unfortunately you only have support for this in CUCM 8.5
03-04-2013 05:19 AM
Thanks for the usefull info!
