Callmanager Upgrade Behavior
f.gouger
What happen for the user during the upgrade from 6.1 to 6.2 for example. I want to know if the user will be affected during the upgrade? And if yes what are the problems?
Jaime Valencia
all the upgrade process takes place in the inactive partition, it can cause high cpu (and all that comes with it) but other than that users will not be aware of it
javalenc
if this helps, please rate
java
Thanks for the reply but some people are telling me that the user will not be able to do some options, like call forward and other stuff like that. It is true or the upgrade is trasparent for the users.
there are 2 partitions, the active and the inactive. ALL the upgrade process takes place in the inactive partition (while you keep working on the active), you need to reboot and switch partitions to start using the new version
javalenc
java
