01-15-2013 04:40 AM - edited 03-16-2019 03:10 PM
when i m changing for command line the password is not changing
01-15-2013 04:46 AM
Try
set password expiry minimum-age disable
The do it again.
Failing that, you could use the 'pwrecovery' 'pwreset' username/password combination from the server console to force a reset.
Aaron
01-15-2013 04:58 AM
HI
I try again its showing same problem
01-15-2013 05:16 AM
when i do this i cannot login to gui administration
01-15-2013 05:20 AM
GUI admin is a different account, even if it also has the username 'admin'. The password for that will be what it was before you tried this procedure.
Aaron
01-15-2013 05:34 AM
when i this set password expiry disable
system admin user name and password is not working from gui
user admin
password xxxx
this one is not working from gui
the disaster recovery and operating system admin username and password is working fine but when when i m changing the password and user name status is showing unsuccess
admin 123
password is working
01-15-2013 05:42 AM
So - if you have managed to reset the platform password, then you don't need to set the minimum-age command. If it causes a problem, take it out...
Aaron
01-15-2013 06:17 AM
Hi Syed,
Just an observation to add to the great tips from my friend Aaron (+5 "A")
the command
was entered
set password expiry minimum_age disable
**Note the underscore in your entry**
Cheers!
Rob
"Spend your life waiting,
for a moment that just don't come,
Well, don't waste your time waiting"
-Springsteen
01-15-2013 06:36 AM
i try this set password expiry minimum-age disable but this command in cli mode its not taking
when set this command set password expiry disable after that login of gui admin username and password is not working
previously it was working
