Calls between Device Pools
carlosjlopez
hi all,
I need to create two different Device Pools in one Call Manager 4.2(3) but when I do that the phones in one Device Pool Can't call to phones in the other one device Pool. All calls inside device pool works fine.
Any ideas?
thanks in advance
6 Replies 6
Jaime Valencia
codecs must be the issue
javalenc
if this helps, please rate
java
Hi Javalenc, thanks for your fast answer, both device pools are in the same region and use the same codec G711
Chris Deren
What is the location set to on the DPs? If it's different ensure that the location configuration has enough bandwidth for the calls.
Also, what type of phones are these?
Chris
as far as i remember location is set on the device and not in the DP. but might be a good idea to check it anyway
what happens when you dial?? what do you hear??
javalenc
java
In CM 4.2 and 6.X it is set in Device Pool.
Chris
In CCM 4.2 and 6.X you can set the location on both the DP and the Device itself!
So please check what locations you have on both and ensure you have enough badnwidth for the call
Please rate all useful posts
