Beginner
Calls disconnect and user gets fast busy
Recently I've been getting more and more people complaining about calls disconnecting. The users are saying that they will be on a call from about 10min to 30min and the calls just drops and they get a fast busy. I wanted to know has anyone seen this before and thanks in advance for the help.
Eric
1 ACCEPTED SOLUTION
Re: Calls disconnect and user gets fast busy
hi,
i suspect the issue could be with session refresher if it is dropping at a fix interval. for more input on this we need the CUCM/Gateway traces.
you can use CSA tool your self and check which party is disconnecting a call through ladder diagram.
https://cway.cisco.com/docs/tools/CollaborationSolutionsAnalyzer/index.html
reach out in case of any query.
Tarun
1 REPLY 1
hi,
Tarun
Content for Community-Ad
August's Community Spotlight Awards
