Calls failure
Siva chinap
Level 5
Level 5
Dear All,
We have one endpoint EX 90 series registered to HQ. When make a Extension calls internally working fine. We have intercluster SIP trunk to another customer site. From EX 90 if i make intercluster calls it's getting failed. In both directions incoming/outgoing. The moment phone rings destination party if answer getting a error message "call disconnected".
In other scenario from From other extnesion in hq to intercluster calls working fine.
Ex90 version tc 5.4.1 , do i need to upgrade the codec to fix the issue?
IF its upgrade do i need to do multistep?
11 Replies 11
Please check u have configured correct codec both sides. i Think there will be codec issue.
u can upgrade version.
Thanks Sandip
Sure let me check that .. In HQ we are using G711 codec.i need to check other end.
Besides audio codec also check video bandwidth in case the device you are calling is also video endpoint.
Chris,
Just trying to make an audio call. Specifically only calls from EX90 endpoint fails.
Since EX90 is a video endpoint it may try to attempt to negotiate video bandwidth, make sure the region and location between the phone and location/region assigned via DP to the SIP/ICT trunk are configured correctly.
Chris,
Please find the logs message
Calling number:8301
called number:3332
59312498.001 |13:49:37.615 |SdlError |SsConnectInfoInd |wait |ForwardManager(2,100,199,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59312554.001 |13:49:47.433 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459662,38459663),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59313918.000 |13:51:51.065 |SdlError |H225ICTThrottlingMonitorTimer |NA |H225D(2,100,194,109) |SdlTimerService(2,100,3,1) |2,100,41,1.2069^*^* |Destination process does not exist
59313919.000 |13:51:51.065 |SdlError |SdlProcessNE |NA |SdlTimerService(2,100,3,1) |H225D(2,100,194,109) |2,100,41,1.2069^*^* |Destination process does not exist
59314128.001 |13:51:53.809 |SdlError |CcRegisterPartyB |tcc_incoming_call_proceeding4 |Cdcc(2,100,219,42608) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59314599.001 |13:52:04.416 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459670,38459671),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59315167.001 |13:52:09.935 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459674,38459675),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59315659.001 |13:52:20.458 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459678,38459679),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59316499.001 |13:52:46.194 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459680,38459681),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59317474.001 |13:53:11.198 |SdlError |MediaDisconnectReply |connecting |MatrixControl(2,100,142,41187) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59318406.001 |13:53:38.477 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459689,0),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59318476.001 |13:53:38.484 |SdlError |SsInsertMediaConnectReply |disconnect_indication12 |StationCdpc(2,100,64,45504) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59318593.000 |13:53:39.375 |SdlError |MediaDisconnectReply |NA |MatrixControl(2,100,142,41192) |ConnectionManager(2,100,214,1) |2,100,14,84703.24592^172.24.129.177^SEPBC671CDCDFB4 |Destination process does not exist
59318594.001 |13:53:39.375 |SdlError |SdlProcessNE |wait |ConnectionManager(2,100,214,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59319166.000 |13:54:45.771 |SdlError |H225ICTThrottlingMonitorTimer |NA |H225D(2,100,194,110) |SdlTimerService(2,100,3,1) |2,100,41,1.2198^*^* |Destination process does not exist
59319167.000 |13:54:45.771 |SdlError |SdlProcessNE |NA |SdlTimerService(2,100,3,1) |H225D(2,100,194,110) |2,100,41,1.2198^*^* |Destination process does not exist
59319302.001 |13:54:51.256 |SdlError |CcRegisterPartyB |tcc_incoming_call_proceeding4 |Cdcc(2,100,219,42618) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59320020.001 |13:55:10.792 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459692,38459693),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59320277.006 |13:55:17.509 |AppInfo |MediaResourceManager::sendAllocationResourceErr - ERROR - no transcoder device configured
59320282.002 |13:55:17.509 |AppInfo |MRM::waiting_DeallocateMtpResourceReq- ERROR Deallocate received for an unknown Call Identifier Ci = 38459700
59320283.000 |13:55:17.509 |SdlSig |MediaConnectErrorInd |wait |MediaCoordinator(2,100,141,1) |MediaManager(2,100,140,41012) |2,100,14,84703.24597^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459698 CI2=38459699 clearType=0 Cause=1
59320283.001 |13:55:17.509 |AppInfo |SIG-MediaCoordinator-wait_MediaConnectErrorInd - removing MediaManager(41012) from connection list
59320286.000 |13:55:17.510 |SdlSig |MediaConnectErrorInd |wait |ConnectionManager(2,100,214,1) |MediaCoordinator(2,100,141,1) |2,100,14,84703.24597^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459698 CI2=38459699 clearType=0 Cause=1
59320286.001 |13:55:17.510 |AppInfo |ARBTRY-ConnectionManager- wait_MediaConnectErrorInd CI(38459698,38459699)
59320287.001 |13:55:17.510 |SdlError |MediaUpdateDisconnectStatus |connecting |MatrixControl(2,100,142,41195) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59320288.000 |13:55:17.510 |SdlSig |MediaConnectErrorInd |connecting |MatrixControl(2,100,142,41195) |ConnectionManager(2,100,214,1) |2,100,14,84703.24597^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=38459698 CI2=38459699 clearType=0 Cause=1
59320291.001 |13:55:17.532 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459698,38459699),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59320296.000 |13:55:17.533 |SdlError |MediaDisconnectReply |NA |MatrixControl(2,100,142,41195) |ConnectionManager(2,100,214,1) |2,100,14,84703.24597^172.24.129.177^SEPBC671CDCDFB4 |Destination process does not exist
59320297.001 |13:55:17.533 |SdlError |SdlProcessNE |wait |ConnectionManager(2,100,214,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59320562.006 |13:55:21.299 |AppInfo |MediaResourceManager::sendAllocationResourceErr - ERROR - no transcoder device configured
59320565.002 |13:55:21.300 |AppInfo |MRM::waiting_DeallocateMtpResourceReq- ERROR Deallocate received for an unknown Call Identifier Ci = 38459703
59320566.000 |13:55:21.300 |SdlSig |MediaConnectErrorInd |wait |MediaCoordinator(2,100,141,1) |MediaManager(2,100,140,41013) |2,100,14,84703.24603^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459701 CI2=38459702 clearType=0 Cause=1
59320566.001 |13:55:21.300 |AppInfo |SIG-MediaCoordinator-wait_MediaConnectErrorInd - removing MediaManager(41013) from connection list
59320568.000 |13:55:21.300 |SdlSig |MediaConnectErrorInd |wait |ConnectionManager(2,100,214,1) |MediaCoordinator(2,100,141,1) |2,100,14,84703.24603^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459701 CI2=38459702 clearType=0 Cause=1
59320568.001 |13:55:21.300 |AppInfo |ARBTRY-ConnectionManager- wait_MediaConnectErrorInd CI(38459701,38459702)
59320569.001 |13:55:21.300 |SdlError |MediaUpdateDisconnectStatus |connecting |MatrixControl(2,100,142,41196) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59320570.000 |13:55:21.300 |SdlSig |MediaConnectErrorInd |connecting |MatrixControl(2,100,142,41196) |ConnectionManager(2,100,214,1) |2,100,14,84703.24603^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=38459701 CI2=38459702 clearType=0 Cause=1
59320572.001 |13:55:21.300 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459701,38459702),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59320575.000 |13:55:21.300 |SdlError |MediaDisconnectReply |NA |MatrixControl(2,100,142,41196) |ConnectionManager(2,100,214,1) |2,100,14,84703.24603^172.24.129.177^SEPBC671CDCDFB4 |Destination process does not exist
59320576.001 |13:55:21.300 |SdlError |SdlProcessNE |wait |ConnectionManager(2,100,214,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59320865.006 |13:55:27.668 |AppInfo |MediaResourceManager::sendAllocationResourceErr - ERROR - no transcoder device configured
59320868.002 |13:55:27.668 |AppInfo |MRM::waiting_DeallocateMtpResourceReq- ERROR Deallocate received for an unknown Call Identifier Ci = 38459706
59320869.000 |13:55:27.668 |SdlSig |MediaConnectErrorInd |wait |MediaCoordinator(2,100,141,1) |MediaManager(2,100,140,41014) |2,100,14,84703.24608^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459704 CI2=38459705 clearType=0 Cause=1
59320869.001 |13:55:27.668 |AppInfo |SIG-MediaCoordinator-wait_MediaConnectErrorInd - removing MediaManager(41014) from connection list
59320871.000 |13:55:27.668 |SdlSig |MediaConnectErrorInd |wait |ConnectionManager(2,100,214,1) |MediaCoordinator(2,100,141,1) |2,100,14,84703.24608^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459704 CI2=38459705 clearType=0 Cause=1
59320871.001 |13:55:27.668 |AppInfo |ARBTRY-ConnectionManager- wait_MediaConnectErrorInd CI(38459704,38459705)
59320872.001 |13:55:27.668 |SdlError |MediaUpdateDisconnectStatus |connecting |MatrixControl(2,100,142,41197) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59320873.000 |13:55:27.668 |SdlSig |MediaConnectErrorInd |connecting |MatrixControl(2,100,142,41197) |ConnectionManager(2,100,214,1) |2,100,14,84703.24608^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=38459704 CI2=38459705 clearType=0 Cause=1
59320875.001 |13:55:27.668 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459704,38459705),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59320878.000 |13:55:27.668 |SdlError |MediaDisconnectReply |NA |MatrixControl(2,100,142,41197) |ConnectionManager(2,100,214,1) |2,100,14,84703.24608^172.24.129.177^SEPBC671CDCDFB4 |Destination process does not exist
59320879.001 |13:55:27.668 |SdlError |SdlProcessNE |wait |ConnectionManager(2,100,214,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59321007.001 |13:55:34.068 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459696,38459697),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59321244.000 |13:55:50.627 |SdlError |H225ICTThrottlingMonitorTimer |NA |H225D(2,100,194,111) |SdlTimerService(2,100,3,1) |2,100,41,1.2204^*^* |Destination process does not exist
59321245.000 |13:55:50.627 |SdlError |SdlProcessNE |NA |SdlTimerService(2,100,3,1) |H225D(2,100,194,111) |2,100,41,1.2204^*^* |Destination process does not exist
59321457.006 |13:55:55.750 |AppInfo |MediaResourceManager::sendAllocationResourceErr - ERROR - no transcoder device configured
59321460.002 |13:55:55.751 |AppInfo |MRM::waiting_DeallocateMtpResourceReq- ERROR Deallocate received for an unknown Call Identifier Ci = 38459709
59321461.000 |13:55:55.751 |SdlSig |MediaConnectErrorInd |wait |MediaCoordinator(2,100,141,1) |MediaManager(2,100,140,41015) |2,100,14,84703.24614^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459707 CI2=38459708 clearType=0 Cause=1
59321461.001 |13:55:55.751 |AppInfo |SIG-MediaCoordinator-wait_MediaConnectErrorInd - removing MediaManager(41015) from connection list
59321463.000 |13:55:55.751 |SdlSig |MediaConnectErrorInd |wait |ConnectionManager(2,100,214,1) |MediaCoordinator(2,100,141,1) |2,100,14,84703.24614^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459707 CI2=38459708 clearType=0 Cause=1
59321463.001 |13:55:55.751 |AppInfo |ARBTRY-ConnectionManager- wait_MediaConnectErrorInd CI(38459707,38459708)
59321464.001 |13:55:55.751 |SdlError |MediaUpdateDisconnectStatus |connecting |MatrixControl(2,100,142,41199) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59321465.000 |13:55:55.751 |SdlSig |MediaConnectErrorInd |connecting |MatrixControl(2,100,142,41199) |ConnectionManager(2,100,214,1) |2,100,14,84703.24614^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=38459707 CI2=38459708 clearType=0 Cause=1
59321467.001 |13:55:55.751 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459707,38459708),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59321470.000 |13:55:55.751 |SdlError |MediaDisconnectReply |NA |MatrixControl(2,100,142,41199) |ConnectionManager(2,100,214,1) |2,100,14,84703.24614^172.24.129.177^SEPBC671CDCDFB4 |Destination process does not exist
59321471.001 |13:55:55.751 |SdlError |SdlProcessNE |wait |ConnectionManager(2,100,214,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59321777.006 |13:56:02.931 |AppInfo |MediaResourceManager::sendAllocationResourceErr - ERROR - no transcoder device configured
59321780.002 |13:56:02.932 |AppInfo |MRM::waiting_DeallocateMtpResourceReq- ERROR Deallocate received for an unknown Call Identifier Ci = 38459712
59321781.000 |13:56:02.932 |SdlSig |MediaConnectErrorInd |wait |MediaCoordinator(2,100,141,1) |MediaManager(2,100,140,41016) |2,100,14,84703.24619^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459710 CI2=38459711 clearType=0 Cause=1
59321781.001 |13:56:02.932 |AppInfo |SIG-MediaCoordinator-wait_MediaConnectErrorInd - removing MediaManager(41016) from connection list
59321783.000 |13:56:02.932 |SdlSig |MediaConnectErrorInd |wait |ConnectionManager(2,100,214,1) |MediaCoordinator(2,100,141,1) |2,100,14,84703.24619^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI1=38459710 CI2=38459711 clearType=0 Cause=1
59321783.001 |13:56:02.932 |AppInfo |ARBTRY-ConnectionManager- wait_MediaConnectErrorInd CI(38459710,38459711)
59321784.001 |13:56:02.932 |SdlError |MediaUpdateDisconnectStatus |connecting |MatrixControl(2,100,142,41200) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59321785.000 |13:56:02.932 |SdlSig |MediaConnectErrorInd |connecting |MatrixControl(2,100,142,41200) |ConnectionManager(2,100,214,1) |2,100,14,84703.24619^172.24.129.177^SEPBC671CDCDFB4 |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=38459710 CI2=38459711 clearType=0 Cause=1
59321787.001 |13:56:02.933 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459710,38459711),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59321790.000 |13:56:02.933 |SdlError |MediaDisconnectReply |NA |MatrixControl(2,100,142,41200) |ConnectionManager(2,100,214,1) |2,100,14,84703.24619^172.24.129.177^SEPBC671CDCDFB4 |Destination process does not exist
59321791.001 |13:56:02.933 |SdlError |SdlProcessNE |wait |ConnectionManager(2,100,214,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59322108.001 |13:56:29.123 |AppError |wait_CtiDeviceRegisterNotifyWithLineInfo ENTER Device=SEPC0626BAD8760
59322108.002 |13:56:29.123 |AppError | senderPid=(2,1072) StationPid=(2,1072)
59322266.001 |13:56:33.096 |AppError |wait_CtiDeviceRegisterNotifyWithLineInfo ENTER Device=SEPC0626BAD8760
59322266.002 |13:56:33.096 |AppError | senderPid=(2,1073) StationPid=(2,1073)
59323148.001 |13:57:04.714 |SdlError |SsOrphanInd |wait |PickupManager(2,100,116,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59323221.001 |13:57:04.722 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459716,0),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59323497.001 |13:57:11.670 |SdlError |SsConnectInfoInd |wait |ForwardManager(2,100,199,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59323498.001 |13:57:11.670 |SdlError |SsConnectInfoInd |wait |PickupManager(2,100,116,1) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59323987.001 |13:57:45.498 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459720,38459721),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59324719.001 |13:57:53.603 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459724,38459725),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59324782.001 |13:57:54.146 |AppError |wait_CtiDeviceRegisterNotifyWithLineInfo ENTER Device=SEPC0626BAD8760
59324782.002 |13:57:54.146 |AppError | senderPid=(2,1074) StationPid=(2,1074)
59325030.001 |13:57:58.136 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459726,38459727),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
59325221.001 |13:58:04.297 |SdlError |CcRegisterPartyB |tcc_incoming_call_proceeding4 |Cdcc(2,100,219,42633) | | |Error: Description: A transition is not defined for the input signal. Check state machine definition in initStateMachine().
59326007.001 |13:59:17.988 |AppInfo |!!ERROR!! -ConnectionManager- wait_MediaDisconnectRequest :CI NOT FOUND IN TABLE,CI(38459728,38459729),discType=1,IFCreated(0,0),PID(0-0,0-0),IFHandling(0,0),MCNode(0,0)
I filter the trace with sip error message 487
Via: SIP/2.0/TCP 172.24.129.135:5060;branch=z9hG4bKab9bbf3ab50143b9efab4434cbe96d95.1;rport
From: "IT Director:Mohamed " <sip:8301@srvadcmsub01>;tag=0da6478e833a29d7
To: <sip:3332@srvadcmsub01>
Date: Thu, 15 Jun 2017 09:52:04 GMT
Call-ID: 0cdc9c4aa48a6634@172.24.129.135
Server: Cisco-CUCM10.5
CSeq: 100 CANCEL
Content-Length: 0
59314589.000 |13:52:04.416 |SdlSig |SIPDisconnInd |wait |SIPStationD(2,100,73,1071) |SIPHandler(2,100,79,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CcbId= 3291202 --TransType=1 --TransSecurity=0 PeerAddr = 172.24.129.135:36341 Sip_disc_cause= 200 cause=16 isReasonHdrVal= F
59314590.000 |13:52:04.416 |SdlSig |SIPDisconnInd |translate |SIPStationCdfc(2,100,74,14495) |SIPStationD(2,100,73,1071) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CcbId= 3291202 --TransType=1 --TransSecurity=0 PeerAddr = 172.24.129.135:36341 Sip_disc_cause= 200 cause=16 isReasonHdrVal= F
59314591.000 |13:52:04.416 |SdlSig |SIPDisconnInd |inCall_delivered |SIPCdpc(2,100,82,15020) |SIPStationCdfc(2,100,74,14495) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:2,L:0,V:0,Z:0,D:0] CcbId= 3291202 --TransType=1 --TransSecurity=0 PeerAddr = 172.24.129.135:36341 Sip_disc_cause= 200 cause=16 isReasonHdrVal= F
59314592.000 |13:52:04.416 |SdlSig |DSetCallPhase |wait |SIPStationD(2,100,73,1071) |SIPStationCdfc(2,100,74,14495) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:2,L:0,V:0,Z:0,D:0] CallPhase=CALL_CLEARING
59314593.000 |13:52:04.416 |SdlSig |DSetCallState |wait |SIPStationD(2,100,73,1071) |SIPStationCdfc(2,100,74,14495) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CallState = disconnect_request11
59314594.000 |13:52:04.416 |SdlSig |CcDisconnInd |restart0 |LineControl(2,100,174,591) |SIPCdpc(2,100,82,15020) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=16 globalDisconnect=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName= CAL={v=ffffffff, m=ffffffff, tDev=F, res=F, devType=0} CAL={v=fffffff6, m=ffffffff, tDev=F, res=F, devType=0}
59314595.000 |13:52:04.416 |SdlSig |CcDisconnInd |call_initiated1 |LineCdpc(2,100,175,54599) |LineControl(2,100,174,591) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=16 globalDisconnect=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName= CAL={v=ffffffff, m=ffffffff, tDev=F, res=F, devType=0} CAL={v=fffffff6, m=ffffffff, tDev=F, res=F, devType=0}
59314596.000 |13:52:04.416 |SdlSig |CcDisconnInd |wait |Cc(2,100,220,1) |LineCdpc(2,100,175,54599) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=16 globalDisconnect=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName= CAL={v=ffffffff, m=ffffffff, tDev=F, res=F, devType=0} CAL={v=fffffff6, m=ffffffff, tDev=F, res=F, devType=0}
59314597.000 |13:52:04.416 |SdlSig |CcDisconnInd |tcc_call_alerting6 |Cdcc(2,100,219,42608) |Cc(2,100,220,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=16 globalDisconnect=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName= CAL={v=ffffffff, m=ffffffff, tDev=F, res=F, devType=0} CAL={v=fffffff6, m=ffffffff, tDev=F, res=F, devType=0}
59314597.001 |13:52:04.416 |Created | | |MatrixControl(2,100,142,41182) |Cdcc(2,100,219,42608) | |NumOfCurrentInstances: 1
59314598.000 |13:52:04.416 |SdlSig |DropPartyReq |await_command |MatrixControl(2,100,142,41182) |Cdcc(2,100,219,42608) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] ClearType= 0
59314599.000 |13:52:04.416 |SdlSig |MediaDisconnectRequest |wait |ConnectionManager(2,100,214,1) |MatrixControl(2,100,142,41182) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=38459670 CI2=38459671 sc=0 disconnType=1 ssReason=0 clearType=0 IF1Created=F IF2Created=F party1.mMediaCoordinatorNodeId=0 party2.mMediaCoordinatorNodeId=0 party1.dtmCall= dtm.mode=0 dtm.CI=0 dtm.MTPForDTMF=F party2.dtmCall= dtm.mode=0 dtm.CI=0 dtm.MTPForDTMF=F reconnectPending=F forceStopCI=0
59314600.000 |13:52:04.416 |SdlSig |MediaDisconnectReply |dissolving |MatrixControl(2,100,142,41182) |ConnectionManager(2,100,214,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI1=38459670 CI2=38459671 sc=245 disconnType=1 ssReason=0 clearType=0 IF1Created=F IF2Created=F party1.mMediaCoordinatorNodeId=0 party2.mMediaCoordinatorNodeId=0 party1.dtmCall= dtm.mode=0 dtm.CI=0 dtm.MTPForDTMF=F party2.dtmCall= dtm.mode=0 dtm.CI=0 dtm.MTPForDTMF=F reconnectPending=F forceStopCI=0
59314600.001 |13:52:04.416 |AppInfo |MatrixControl:updatePartyMediaCoordinatorNodeId: party1 videoCapable=1, party 2 videocapable=1
59314600.002 |13:52:04.416 |Stopping | | |MatrixControl(2,100,142,41182) |MatrixControl(2,100,142,41182) | |NumOfCurrentInstances: 1
59314601.000 |13:52:04.416 |SdlSig |DropErr |disconnect_clearing_profile |Cdcc(2,100,219,42608) |MatrixControl(2,100,142,41182) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] MediaStatusCode= 245
59314602.000 |13:52:04.416 |SdlSig |CcDisconnReq |restart0 |H225D(2,100,194,110) |Cdcc(2,100,219,42608) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI=38459671 CI.branch=0 clearType=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=16 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=F OnBehalf=Device rfr=0 localPatternUsage=2 connectedPatternUsage=5 rdDestPart= rdDestPatt= rdDestCdpn=pi=0si1 lrnCepn= redDestName=locale: 1 Name: UnicodeName: pi: 0 annId=0 lHPMemCEPN= cHPMemCEPN= dtmCall=F dtmDisconn=F dtmMcNodeId=0 forcedClear=F TransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName= mediaCause=0 CAL={v=ffffffff, m=ffffffff, tDev=F, res=F, devType=0} CAL={v=fffffff6, m=ffffffff, tDev=F, res=F, devType=0}
59314603.000 |13:52:04.416 |SdlSig |CcRelReq |restart0 |LineControl(2,100,174,591) |Cdcc(2,100,219,42608) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=0 dtmCall=F dtmDisconn=F dtmMcNodeId=0 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314604.000 |13:52:04.416 |SdlSig |CcDisconnReq |call_received7 |H225Cdpc(2,100,195,27458) |H225D(2,100,194,110) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI=38459671 CI.branch=0 clearType=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 cv=16 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=F OnBehalf=Device rfr=0 localPatternUsage=2 connectedPatternUsage=5 rdDestPart= rdDestPatt= rdDestCdpn=pi=0si1 lrnCepn= redDestName=locale: 1 Name: UnicodeName: pi: 0 annId=0 lHPMemCEPN= cHPMemCEPN= dtmCall=F dtmDisconn=F dtmMcNodeId=0 forcedClear=F TransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName= mediaCause=0 CAL={v=ffffffff, m=ffffffff, tDev=F, res=F, devType=0} CAL={v=fffffff6, m=ffffffff, tDev=F, res=F, devType=0}
59314605.000 |13:52:04.417 |SdlSig |CcRelReq |call_initiated1 |LineCdpc(2,100,175,54599) |LineControl(2,100,174,591) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:5,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=0 dtmCall=F dtmDisconn=F dtmMcNodeId=0 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314606.000 |13:52:04.417 |SdlSig |CcRelInd |wait |Cc(2,100,220,1) |H225Cdpc(2,100,195,27458) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:5,L:0,V:0,Z:0,D:0] CI=38459671 CI.branch=0 c.l=0 isDeskPickup=F dtmDisconn=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314607.000 |13:52:04.417 |SdlSig |DSetCallPhase |restart0 |H225D(2,100,194,110) |H225Cdpc(2,100,195,27458) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:5,L:0,V:0,Z:0,D:0] CallPhase=CALL_CLEARING
59314608.000 |13:52:04.417 |SdlSig |DStopInd |restart0 |H225D(2,100,194,110) |H225Cdpc(2,100,195,27458) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:4,L:0,V:0,Z:0,D:0]
59314609.000 |13:52:04.417 |SdlSig |PolicyAndCACUnregisterReq |wait |ReservationMgr(2,100,110,1) |H225Cdpc(2,100,195,27458) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:4,L:0,V:0,Z:0,D:0] CI= 38459671 ClearType=0
59314610.000 |13:52:04.417 |SdlSig-O |CcRelReq |NA RemoteSignal |SIPStationD(3,100,73,234) |LineCdpc(2,100,175,54599) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:5,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=0 dtmCall=F dtmDisconn=F dtmMcNodeId=0 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314611.000 |13:52:04.417 |SdlSig |CcRelReq |wait |SIPStationD(2,100,73,1071) |LineCdpc(2,100,175,54599) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:4,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=0 dtmCall=F dtmDisconn=F dtmMcNodeId=0 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314612.000 |13:52:04.417 |SdlSig |CcRelInd |tcc_await_two_way_release10 |Cdcc(2,100,219,42608) |Cc(2,100,220,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:4,L:0,V:0,Z:0,D:0] CI=38459671 CI.branch=0 c.l=0 isDeskPickup=F dtmDisconn=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314613.000 |13:52:04.417 |SdlSig |DStopConf |stop_indication |H225Cdpc(2,100,195,27458) |H225D(2,100,194,110) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:3,L:0,V:0,Z:0,D:0] varChannelStatus=0
59314614.000 |13:52:04.417 |SdlSig |CACUnregisterReq |wait |RSVPSession(2,100,107,42611) |ReservationMgr(2,100,110,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:2,L:0,V:0,Z:0,D:0] CI= 38459671 ClearType=0
59314615.000 |13:52:04.417 |SdlSig |H225RelComplete |wait |H225Handler(2,100,193,1) |H225Cdpc(2,100,195,27458) |2,100,14,92437.15^172.24.129.135^* |[T:N-H:0,N:0,L:0,V:0,Z:0,D:0] CES=0 SAPI=0 DSL=0 IEP=0 PID=(2,100,14,92443)
59314616.000 |13:52:04.417 |SdlSig |CcRelReq |disconnect_indication12 |SIPStationCdfc(2,100,74,14495) |SIPStationD(2,100,73,1071) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=0 dtmCall=F dtmDisconn=F dtmMcNodeId=0 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314617.000 |13:52:04.417 |SdlSig |CcRelReq |disconnectRcvd |SIPCdpc(2,100,82,15020) |SIPStationCdfc(2,100,74,14495) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=0 dtmCall=F dtmDisconn=F dtmMcNodeId=0 FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314618.000 |13:52:04.417 |SdlSig |CcRelInd |restart0 |LineControl(2,100,174,591) |SIPCdpc(2,100,82,15020) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 CV=0 isDeskPickup=F dtmDisconn=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314619.000 |13:52:04.417 |SdlSig |CcRelInd |call_initiated1 |LineCdpc(2,100,175,54599) |LineControl(2,100,174,591) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 CV=0 isDeskPickup=F dtmDisconn=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314615.001 |13:52:04.417 |AppInfo |value H323-UserInformation ::=
59314620.000 |13:52:04.417 |SdlSig |CcRelInd |wait |Cc(2,100,220,1) |LineCdpc(2,100,175,54599) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:2,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 CV=0 isDeskPickup=F dtmDisconn=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314621.000 |13:52:04.417 |SdlSig-O |LmKeyReleaseReq |NA RemoteSignal |SIPStationD(3,100,73,234) |LineCdpc(2,100,175,54599) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:2,L:0,V:0,Z:0,D:0] CI=38459670
59314622.000 |13:52:04.417 |SdlSig |DStopInd |restart0 |LineControl(2,100,174,591) |LineCdpc(2,100,175,54599) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0]
59314615.002 |13:52:04.417 |AppInfo |{
h323-uu-pdu
h323-message-body releaseComplete :
protocolIdentifier { 0 0 8 2250 0 5 },
callIdentifier
guid '00084A41B958219401001502AC188187'H
h245Tunneling FALSE
59314615.003 |13:52:04.417 |AppInfo |}
59314623.000 |13:52:04.417 |SdlSig |CcRelInd |tcc_await_incoming_release8 |Cdcc(2,100,219,42608) |Cc(2,100,220,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] CI=38459670 CI.branch=0 c.l=1 c.cid=8 c.cs=0 c.lc=0 c.r=0 CV=0 isDeskPickup=F dtmDisconn=F FDataType=0opId=0ssType=0 SsKey=0invokeId=0resultExp=Fbpda=FTransparentData=null CanSupportSIPTandN=false TransId=0 AllowBitMask=0x0 UserAgentOrServer= OrigDDName=locale: 1 Name: UnicodeName: pi: 0 mCallerId= mCallerName=
59314624.000 |13:52:04.417 |SdlSig |DStopConf |call_initiated1 |LineCdpc(2,100,175,54599) |LineControl(2,100,174,591) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:1,L:0,V:0,Z:0,D:0] varChannelStatus=0
59314624.001 |13:52:04.417 |Stopping | | |LineCdpc(2,100,175,54599) |LineCdpc(2,100,175,54599) | |NumOfCurrentInstances: 3
59314625.000 |13:52:04.417 |SdlSig |PolicyAndCACUnassociateReq |wait |ReservationMgr(2,100,110,1) |Cdcc(2,100,219,42608) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI= 38459670 aCI=38459670 bCI=38459671 ClearType=0
59314626.000 |13:52:04.417 |SdlSig |CACUnassociateReq |wait |RSVPSession(2,100,107,42611) |ReservationMgr(2,100,110,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0] CI= 38459670 aCI=38459670 bCI=38459671 ClearType=0
59314627.000 |13:52:04.417 |SdlSig |RSVPStopInd |wait |ReservationMgr(2,100,110,1) |RSVPSession(2,100,107,42611) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]
59314628.000 |13:52:04.417 |SdlSig |RSVPStopConf |wait |RSVPSession(2,100,107,42611) |ReservationMgr(2,100,110,1) |2,100,14,92437.15^172.24.129.135^* |[R:N-H:0,N:0,L:0,V:0,Z:0,D:0]
59314628.001 |13:52:04.417 |Stopping | | |RSVPSession(2,100,107,42611) |RSVPSession(2,100,107,42611) | |NumOfCurrentInstances: 4
59314629.000 |13:52:04.417 |SdlSig |DbCdrReq |wait |EnvProcessCdr(2,100,249,1) |Cdcc(2,100,219,42608) |2,100,14,92437.15^172.24.129.135^* |[T:N-H:0,N:0,L:0,V:0,Z:0,D:0] 01000000 02000000 26ce0500 16d94a02 b9584259 02000000 00000000 ac188187 6d6d7361 6c727900 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000050 00000000 10000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 53455043 30363236 42414438 37363000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00204737 00000000 04000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00362052 00000000 17d94a02 02000000 17d94a02 ac189c06 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000078 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 4d4f4a5f 50505f54 52554e4b 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00757374 00000000 04000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 c4584259 00000000 02000000 03000000 00000000 05000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00006d3d 00000000 00000000 00000000 38333031 00565020 39372039 38203939 f8656811 f4656811 5ace6111 41533a37 36383030 300d0a61 59ce6111 48ce6111 00372048 3236342f 39303030 300d0a61 24666811 24666811 40b3c20d 80ba3611 b8247110 33333332 003d3432 38303136 3b6d6178 4c666811 48666811 006d6178 2d6d6270 733d3234 35303030 60666811 60666811 00303030 3b6d6178 2d736d62 70733d32 78666811 78666811 f837f910 286c5011 00000000 33333332 006d6170 3a393820 48323634 a0666811 9c666811 003d666d 74703a39 38207072 6f66696c b4666811 b4666811 d02c4e11 80294d11 00de4e11 33333332 00353030 303b6d61 782d6d62 dc666811 d8666811 003b6d61 782d6673 3d393030 303b6d61 f0666811 f0666811 909dba0d 38d5d210 60655311 f88d6f11 00696f6e 2d6d6f64 653d313b 6d61782d 18676811 18676811 00000000 00000000 00000000 00000000 00000000 00000000 00000000 38333031 00666d74 703a3939 20637573 50676811 4c676811 00373638 2c333b63 7573746f 6d3d3132 64676811 64676811 3137322e 32342e31 32392e31 33350038 8a676811 7c676811 003d3130 32342c35 37362c32 3b637573 94676811 94676811 00000000 00000000 02000000 f8953f11 00000000 0032302c 3438302c 313b6375 73746f6d c0676811 c0676811 00000000 00000000 00000000 00000000 00000000 00000000 003b6375 73746f6d 3d333532 2c323430 f0676811 f0676811 003b6d61 7862723d 37363830 0d0a613d 08686811 08686811 00000000
59314629.001 |13:52:04.417 |AppInfo |EnvProcessCdr::wait_DbCdrReq DETAILED Entries 41059, Inserts 41059, ZeroCalls 0, StartRecords 0, Default 0
59314629.002 |13:52:04.417 |AppInfo |EnvProcessCdr::formatCdrData
59314630.000 |13:52:04.417 |SdlSig |SIPRelReq |wait |SIPHandler(2,100,79,1) |SIPCdpc(2,100,82,15020) |2,100,14,92437.15^172.24.129.135^* |[T:N-H:0,N:0,L:0,V:0,Z:0,D:0] CcbId= 3291202 --TransType=1 --TransSecurity=0 PeerAddr = 172.24.129.135:36341 ccCause= 0 sip_disc_cause= 0
59314630.001 |13:52:04.418 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/sip_stop_timer: type=SIP_TIMER_CONNECT value=500 retries=6
59314630.002 |13:52:04.418 |AppInfo |//SIP/SIPHandler/ccbId=0/scbId=0/sip_start_timer: type=SIP_TIMER_CONNECT value=500 retries=6
59314631.000 |13:52:04.418 |SdlSig |SIPSPISignal |wait |SIPTcp(2,100,71,1) |SIPHandler(2,100,79,1) |2,100,14,92437.15^172.24.129.135^* |*TraceFlagOverrode
59314631.001 |13:52:04.418 |AppInfo |SIPTcp - wait_SdlSPISignal: Outgoing SIP TCP message to 172.24.129.135 on port 36341 index 41701
[9174441,NET]
SIP/2.0 487 Request Cancelled
Can you let us know what the immersive video bandwidth between the trunk and phone's region is?  You need to make sure it is something other than NONE.
Crhis,
I thing it was Hub_None. i upgraded the codec to latest version. After that Video call started working wiered. From the logs any idea ?
Jon Clark1
**ERROR**: Ux_Status: STATUS call state mismatch with invalid cause: cause 0x61, state 0xB, peer state 0xA
One engineer believes its a codec mismatch. Another engineer believes it's a Telco issue...
065076: Oct 17 15:14:04.973: %ISDN-6-DISCONNECT: Interface Serial0/1/0:22 disconnected from 5075258935 , call lasted 1 seconds
065077: Oct 17 15:14:04.974: ISDN Se0/1/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x0146
Cause i = 0x80EF - Protocol error; unspecified
065078: Oct 17 15:14:05.019: ISDN Se0/1/0:23 Q931: RX <- STATUS pd = 8 callref = 0x8146
Cause i = 0x82E16E - Message type not implemented
Call State i = 0x0A
065079: Oct 17 15:14:05.019: ISDN Se0/1/0:23 **ERROR**: Ux_Status: STATUS call state mismatch with invalid cause: cause 0x61, state 0xB, peer state 0xA
065080: Oct 17 15:14:05.020: ISDN Se0/1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0146
Cause i = 0xC0E5 - Message not compatible with call state
065081: Oct 17 15:14:05.028: ISDN Se0/1/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x8146
Cause i = 0x82E408 - Invalid information element contents
065082: Oct 17 15:14:05.031: //300767/A6B0B9800000/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x7FC4A44F36A0, Tag=0x0, Call Id=300767,
Call Entry(Disconnect Cause=111, Voice Class Cause Code=0, Retry Count=0)
065083: Oct 17 15:14:05.031: //300767/A6B0B9800000/CCAPI/cc_api_call_disconnect_done:
Anyone?
Dennis Mink
Typical codec mismatch behaviour. Chech the apllicable region settings across the ic trunk
Please remember to rate useful posts, by clicking on the stars below.
