Highlighted
Beginner
Calls follow rotating schedule?
We are running CUCM/Unity 11.5. We have several departments that have on-call cell phones that they pass to another team member each week.
I would like to be able to setup a rotating schedule for after hours calls to forward to the cell phone of the person who is on-call.
Is there any way to do this?
3 REPLIES 3
Hall of Fame Cisco Employee
Depending on how complex this
Depending on how complex this is, you could use ToD on CUCM
java
if this helps, please rate
Beginner
This is more complicated than
Sorry, I didn't make it clear that I would like to replace these on-call cell phones with a schedule that forwards calls to an individuals cell/home phone.
This is more complicated than just time of day routing. For example, say the department has 3 members that currently share the on-call phone. Instead, each week the calls would go to a different person on their personal phone.
Week 1 - Bob
Week 2 - John
Week 3 - Matt
then repeat
Week 4 - Bob
Week 5 - John
Week 6 - Matt
I know I could setup one extension and change the call forwarding each week. But I would like to set it up once and then only it touch if changes are needed.
I do not believe you can do
I do not believe you can do that with CUCM or CUC, there's no way to tell the config to repeat after x amount of weeks, you might be able to do something like that, but it wold involve some custom development and use the external call control feature in CUCM
java
Content for Community-Ad
August's Community Spotlight Awards
