calls from unknown numbers, how to block in cucm
esaa786
Frequent Visitor
Frequent Visitor
Hi Teams
I have problem in my office DID, keep getting calls from a particular number. Below is the user complaint.
This number 860-273-9969 Keeps calling me - it says its Aetna - But when i try to answer no one speaks and then immediately hangs up never leaves a message
is there any way to block this number through call manager? we are using cucm 14.x
immediate solution is appreciated.
Esa
Thank you Roger for the useful Link for the issue
Esa
Esa
You’re welcome. How come you selected your response as the solution to your question?
If you did that by mistake please update this by deselecting your reply as the solution and select my response for this.
Response Signature
Vaijanath Sonvane
You can also block calls based on ANI at Voice Gateway Level. Please see below post:
https://community.cisco.com/t5/collaboration-knowledge-base/block-incoming-calls-based-off-of-ani-incoming-or-originating/ta-p/3129236
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
