Calls not able to route out of the local gateway
monasir
I am not able to place calls from my ucm phones to my pstn site.
What i did is the following:
I created routegroups, ( added my branch gateway in selected devices also the same thing for my hq router.
Created dial-peers in my hq router:
I am not able to call 911 to my pstn site, i created a routepattern in cucm which is pointing to my local gateway of cucm.
I'm hearing a busy tone., i am able to call from pstn to hq and branch sites.
In my hq and branch router if i debug i don't see nothing comes in.
I also created 2 calling party transformation patterns ( 1XXX and 5XXX)
I have to send a e164 format number to the pstn site. ( +1212394XXX) i also did this.
Voice translation rules also have been created.
But somethings goes wrong, i don't see the call arrives in the gateway when i debug isdn.
The strang part of this task is that i have to create a RL in cucm and point it to the created routed pattern (911)
When placing a call to the hq site i see its going true the branch1 gateway.
HQ router
HQ-RTR#sh run
Building configuration...
Current configuration : 3360 bytes
! Last configuration change at 12:46:03 PST Mon Jan 28 2013
! NVRAM config last updated at 12:45:36 PST Mon Jan 28 2013
version 12.4
hostname HQ-RTR
boot-start-marker
boot-end-marker
logging message-counter syslog
no aaa new-model
clock timezone PST -8
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
no ipv6 cef
isdn switch-type primary-ni
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class h323 1
  h225 timeout tcp establish 3
voice translation-rule 911
rule 1 /^1/ /+1/
voice translation-profile ANI-OUT
translate calling 911
voice-card 0
archive
log config
  hidekeys
controller T1 0/2/0
pri-group timeslots 1-3,24
controller T1 0/2/1
interface Loopback0
ip address 10.10.110.1 255.255.255.255
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.10
encapsulation dot1Q 10 native
ip address 10.10.100.1 255.255.255.0
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 10.10.200.3 255.255.255.0
ip helper-address 10.10.210.10
h323-gateway voip bind srcaddr 10.10.200.3
interface FastEthernet0/0.30
encapsulation dot1Q 30
ip address 10.10.210.1 255.255.255.0
interface FastEthernet0/1
no ip address
speed 100
full-duplex
interface Serial0/1/0
description network connection to Branch1 router
ip address 10.10.111.1 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
clock rate 64000
interface Serial0/1/1
description network connection to Branch2 router
ip address 10.10.112.1 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
clock rate 64000
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn outgoing display-ie
no cdp enable
interface Serial0/3/0
no ip address
shutdown
no fair-queue
router ospf 1
log-adjacency-changes
network 0.0.0.0 255.255.255.255 area 0
ip forward-protocol nd
no ip http server
ip http authentication local
no ip http secure-server
disable-eadi
control-plane
voice-port 0/2/0:23
ccm-manager fax protocol cisco
dial-peer voice 1 pots
incoming called-number .
direct-inward-dial
dial-peer voice 5001 voip
destination-pattern 2123945...
voice-class codec 1
voice-class h323 1
session target ipv4:10.10.210.10
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 911 pots
translation-profile outgoing ANI-OUT
destination-pattern 911
no digit-strip
port 0/2/0:23
forward-digits 3
sip-ua
retry invite 2
timers trying 300
gatekeeper
zone local PL proctorlabs.com
zone prefix PL 1... gw-priority 10 gk-trunk_2
zone prefix PL 1... gw-priority 9 gk-trunk_1
zone prefix PL 1... gw-priority 0 BR2-RTR
zone prefix PL 5... gw-priority 10 gk-trunk_2
zone prefix PL 5... gw-priority 9 gk-trunk_1
zone prefix PL 5... gw-priority 0 BR2-RTR
no shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
password cisco
login
transport input telnet
scheduler allocate 20000 1000
ntp source Loopback0
ntp master 5
ntp server 10.10.210.1
end
Branch1 router
BR1-RTR#sh run
Current configuration : 2818 bytes
version 12.4
hostname BR1-RTR
boot-start-marker
boot-end-marker
enable secret 5 $1$wNOA$XSwMLgrwkVM.XnurXmwyJ.
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip domain name proctorlabs.com
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
controller T1 0/2/0
pri-group timeslots 1-3,24 service mgcp
controller T1 0/2/1
interface Loopback0
ip address 10.10.110.2 255.255.255.255
ip ospf network point-to-point
ip address 10.10.210.16 255.255.255.0
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
switchport trunk native vlan 130
switchport mode trunk
switchport voice vlan 240
interface FastEthernet0/1/1
interface FastEthernet0/1/2
interface FastEthernet0/1/3
no ip address
encapsulation hdlc
isdn bind-l3 ccm-manager
no cdp enable
ip address 10.10.111.2 255.255.255.0
encapsulation ppp
ip ospf mtu-ignore
interface Serial0/3/1
no ip address
clock rate 2000000
interface Vlan1
no ip address
interface Vlan130
ip address 10.10.101.1 255.255.255.0
interface Vlan240
ip address 10.10.201.1 255.255.255.0
router ospf 1
no ip http server
disable-eadi
control-plane
voice-port 0/2/0:23
ccm-manager switchback immediate
ccm-manager redundant-host 10.10.210.10
ccm-manager mgcp
mgcp
mgcp call-agent 10.10.210.10 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
password cisco
login
line aux 0
line vty 0 4
exec-timeout 0 0
privilege level 15
password cisco
login
transport preferred none
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
no login
end
16 Replies 16
Great, please rate all useful posts!
Chris
Thx
