Beginner
Calls not forwarding to external number
Greetings,
I am beating my head over this issue... Calls will not forward to an external number at all and either get the 'this number is out of service' message or 'we are unable to complete your request' message.
Network Overview for VOICE:
Metro Ethernet -> PRI over Fiber -> CIENA Switch -> Adtran -> Cisco 3825 (CUCME 8.6) -> Phones and Devices
I called Comcast Enterprise Support and they are saying that when forwarded all that is being sent as the requesting number is the 4 digit DID. I have gone through the config from top to bottom and am either missing something or not sure what to look for.
Here is my config and debug info.
CONFIG:
Building configuration...
Current configuration : 17386 bytes
! Last configuration change at 01:03:34 DST Wed Jun 19 2013 by daniel.jones
! NVRAM config last updated at 00:59:10 DST Wed Jun 19 2013 by daniel.jones
version 15.1
hostname RJB-VOICE
boot-start-marker
boot-end-marker
enable secret 4 xxxxxxxxxxxxxxxx
no aaa new-model
clock timezone PST -8 0
clock summer-time DST recurring
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 10.30.0.1 10.30.0.10
ip dhcp excluded-address 10.30.0.240 10.30.0.254
ip dhcp pool VOICE-SCOPE
network 10.30.0.0 255.255.255.0
default-router 10.30.0.1
option 150 ip 10.30.0.1
dns-server 4.2.2.2 8.8.8.8 75.75.75.75
option 66 ip 10.30.0.1
option 32 ip 10.30.0.1
option 151 ip 10.30.0.1
no ipv6 cef
isdn switch-type primary-ni
ctl-client
server cme-tftp 10.30.0.1 username xxxxxxx password 1 xxxxxxxxxxxxxx
voice-card 0
dsp services dspfarm
voice service pots
translate incoming controller T1 0/2/0 called 1
translate incoming controller T1 0/2/0 calling 1
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service h225-notify cid-update
fax protocol t38 nse version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0.30
  bind media source-interface GigabitEthernet0/0.30
  e911
  registrar server
voice class codec 1
codec preference 3 g711ulaw
voice register global
mode cme
source-address 10.30.0.1 port 5060
max-dn 450
max-pool 144
load 9971 sip9971.9-1-1SR1
authenticate register
authenticate realm all
time-format 24
voicemail 8999
tftp-path flash:
file text
create profile sync 0120753382730164
ntp-server 10.30.0.2 mode directedbroadcast
camera
video
voice register dn  4
name Bill
voice register dn  5
name Nick Beck
voice register dn  6
name JT
voice register dn  7
name Jon
voice register dn  21
number 1444
shared-line
voice register dn  23
number 0431
shared-line
voice register dn  24
number 0607
shared-line
voice register dn  25
number 6132
shared-line
voice register dn  26
number 4742
shared-line
voice register dn  27
number 8972
shared-line
voice register dn  28
number 6537
shared-line
voice register dn  30
number 8711
voice register dn  31
number 8712
voice register dn  32
number 8713
voice register dn  33
number 8714
voice register dn  34
number 8715
voice register dn  35
number 8716
voice register dn  36
number 8717
voice register dn  37
number 8718
voice register dn  38
number 8719
voice register dn  100
number 1444
shared-line max-calls 6
voice register dn  102
number 4258200431
voice register dn  103
number 4258200607
voice register dn  104
number 4258206132
voice register dn  105
number 4258214742
voice register dn  106
number 4258218972
voice register dn  107
number 4258236537
voice register dialplan 1
type 7940-7960-others
voice register dialplan 2
voice register pool  2
id mac 1C17.D336.5D9E
type 9971
number 1 dn 21
number 2 dn 25
number 3 dn 23
number 4 dn 24
number 5 dn 26
number 6 dn 30
dialplan 1
username rjb1 password 1234
voice register pool  3
id mac ACA0.16FC.9AA8
type 9971
number 1 dn 21
number 2 dn 25
number 3 dn 23
number 4 dn 24
number 5 dn 26
number 6 dn 31
dialplan 1
username RJB password 1234
voice register pool  4
id mac 1C17.D341.8FDC
type 9971
number 1 dn 32
number 2 dn 21
number 3 dn 25
number 4 dn 23
number 5 dn 24
number 6 dn 26
dialplan 1
username RJB4 password 1234
voice register pool  5
id mac ECC8.82B1.4728
type 9971
number 1 dn 33
number 2 dn 21
number 3 dn 25
number 4 dn 23
number 5 dn 24
number 6 dn 26
dialplan 1
username rjb5 password 1234
voice register pool  6
id mac 0008.3030.6DEB
type 9971
number 1 dn 34
number 2 dn 26
number 3 dn 25
number 4 dn 24
number 5 dn 23
number 6 dn 21
username Nick password 1234
after-hour exempt
voice register pool  7
id mac F4EA.6749.1228
type 9971
number 1 dn 35
number 2 dn 21
number 3 dn 25
number 4 dn 23
number 5 dn 24
number 6 dn 26
dialplan 1
username bill password 1234
voice register pool  17
voice register pool  19
voice register pool  25
id mac 000D.BC50.DD9D
number 1 dn 21
number 2 dn 25
number 3 dn 23
number 4 dn 24
number 5 dn 26
number 6 dn 27
dialplan 1
username rjbfire2 password 1234
voice register pool  135
id mac 0000.74C5.3354
voice statistics time-range periodic 15minutes start 00:00 end 00:00 days-of-week daily
voice translation-rule 1
rule 1 /1231/ /94259681231/
voice translation-rule 7
rule 1 /7353/ /4258217353/ type national national
voice translation-rule 8
rule 1 /^8\(...$\)/ /1425406\1/ type unknown national plan unknown isdn
voice translation-rule 9
rule 1 /7353/ /4258217353/ type unknown national plan unknown isdn
voice translation-rule 100
rule 2 /1231/ /4259681231/
voice translation-profile 1
translate calling 100
voice translation-profile OUTGOING-PRIMARY
translate called 8
voice translation-profile fax
translate redirect-target 1
fax receive called-subscriber $d$
fax interface-type fax-mail
crypto pki trustpoint TP-self-signed-2065827382
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2065827382
revocation-check none
rsakeypair TP-self-signed-2065827382
crypto pki certificate chain TP-self-signed-2065827382
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303635 38323733 3832301E 170D3133 30363130 32333337
  33305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30363538
  32373338 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B4E0 31F13DDD 51D46204 97DFCAC4 3A27EAFF 6F682FAF 21B58BB8 446CD078
  22A4CD0F 54321D67 F4F9566B 729D3F2D 3B970DF8 38C53AEB D5FA142D 72A2F687
  383DA8D2 74FE43FC FE7523B8 5955A4D5 9E34D87C 94F28D79 AEFE6FB9 856381E0
  4B5C91C9 6D32FBCA F05882EC A799DF86 C3008C31 C57063F3 E3E8792D 73AED244
  14610203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 14C27769 4ADD89A3 D9DAE2B3 5B006B94 52C24FC4 02301D06
  03551D0E 04160414 C277694A DD89A3D9 DAE2B35B 006B9452 C24FC402 300D0609
  2A864886 F70D0101 05050003 81810013 76BD9685 5EFD021D 1A94982C 38E60353
  1E0C89A3 80DCC961 AAF62B56 863E672D E44F66A7 D078DFF6 2E311291 08A931A5
  BADFDAC1 1FC8056C 4AF6640E 85892232 4AF9B94F FFEE2E90 73BAAA20 08FCA01F
  CC0C503B 014D1E53 372507E5 DE9307AF DC9D6472 7E0CBB93 4C41F7CF 657AF890
  83A64E32 804024D6 988E8832 2676E4
            quit
license udi pid CISCO3825 sn xxxxxxxxxxxx
archive
log config
  hidekeys
username xxxxx privilege 15 secret 4 OeSaoVjxQMWeR5VCrtx5rnMXEZO3V.2kuDBgStgh5Ks
username xxxxxx secret 4 0.7.5uddTBi..dB4EPD5drOljE5DbmC6EYgRLs4zCH2
username xxxx
redundancy
controller T1 0/2/0
pri-group timeslots 1-7,24
description COMCAST-PRI
no ip ftp passive
translation-rule 2
translation-rule 50
interface Tunnel1
no ip address
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.10
encapsulation dot1Q 1 native
ip address 192.168.60.253 255.255.255.0
h323-gateway voip interface
h323-gateway voip id FAX ipaddr 192.168.60.0 1719
h323-gateway voip h323-id FAX
h323-gateway voip tech-prefix 9#
encapsulation dot1Q 30
ip address 10.30.0.1 255.255.255.0
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn map address . plan unknown type unknown
isdn supp-service name calling
isdn send-alerting
no cdp enable
interface Service-Engine2/0
ip unnumbered GigabitEthernet0/0.30
service-module ip address 10.30.0.5 255.255.255.0
service-module ip default-gateway 10.30.0.1
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:GUI
ip route 0.0.0.0 0.0.0.0 10.30.0.2
ip route 0.0.0.0 0.0.0.0 192.168.60.254
ip route 10.30.0.5 255.255.255.255 Service-Engine2/0
snmp-server community public RO
snmp-server community RJBsnmpRW RW
snmp-server contact xxxxx
snmp-server system-shutdown
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server enable traps frame-relay multilink bundle-mismatch
tftp-server flash:sip9971.9-1-1SR1.loads alias sip9971.9-1-1SR1.loads
tftp-server flash:dkern9971.100609R2-9-1-1SR1.sebn alias dkern9971.100609R2-9-1-1SR1.sebn
tftp-server flash:kern9971.9-1-1SR1.sebn alias kern9971.9-1-1SR1.sebn
tftp-server flash:rootfs9971.9-1-1SR1.sebn alias rootfs9971.9-1-1SR1.sebn
tftp-server flash:sboot9971.031610R1-9-1-1SR1.sebn alias sboot9971.031610R1-9-1-1SR1.sebn
tftp-server flash:skern9971.022809R2-9-1-1SR1.sebn alias skern9971.022809R2-9-1-1SR1.sebn
tftp-server flash:ATA187.9-2-3-1.loads alias ATA187.9-2-3-1.loads
tftp-server flash:APPATA187.9-2-3-1.img.sgn alias APPATA187.9-2-3-1.img.sgn
tftp-server flash:BFSATA187.9-2-3-1.img.sgn alias BFSATA187.9-2-3-1.img.sgn
tftp-server flash:KNLATA187.9-2-3-1.bin.sgn alias KNLATA187.9-2-3-1.bin.sgn
tftp-server flash:ATA20370616ECB2.cnf.xml alias ATA20370616ECB2.cnf.xml
tftp-server flash:ATA30370616ECB2.cnf.xml alias ATA30370616ECB2.cnf.xml
tftp-server flash:ATA370616ECB201.cnf.xml alias ATA370616ECB201.cnf.xml
tftp-server flash:/P00308010200.bin alias P00308010200.bin
control-plane
voice-port 0/2/0:23
no ccm-manager fax protocol cisco
mgcp
mgcp modem passthrough voip mode nse
mgcp default-package fxr-package
mgcp fax t38 nsf 000000
mgcp profile default
sccp local GigabitEthernet0/0.30
sccp ccm 10.30.0.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate profile 1 register MTP001
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 mtp
description MTP001
codec g711ulaw
maximum sessions software 400
associate application SCCP
shutdown
dial-peer cor custom
name 911
name local
name ld
name intl
name uptolocal
dial-peer cor list 911
member 911
dial-peer cor list local
member local
dial-peer cor list ld
member ld
dial-peer cor list intl
member intl
dial-peer cor list uptolocal
member 911
member local
dial-peer voice 2000 voip
service session
destination-pattern 87..
session target ipv4:10.30.0.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 4 pots
destination-pattern 4259681231
clid override rdnis
port 0/2/0:23
dial-peer voice 100 pots
description **Incoming Calls**
incoming called-number ....
direct-inward-dial
port 0/2/0:23
forward-digits 4
dial-peer voice 103 pots
description ** T1 PRI pots dial-peer **
destination-pattern 9..........
direct-inward-dial
port 0/2/0:23
forward-digits 10
dial-peer voice 104 pots
destination-pattern 91[2-9].........
clid override rdnis
port 0/2/0:23
forward-digits 11
dial-peer voice 105 pots
description ** T1 PRI pots dial-peer--International **
destination-pattern 9011T
port 0/2/0:23
prefix 011
dial-peer voice 106 pots
description ** T1 PRI pots dial-peer--911 Emergency **
destination-pattern 911
port 0/2/0:23
prefix 911
dial-peer voice 107 pots
destination-pattern 9911
port 0/2/0:23
prefix 911
dial-peer voice 2 pots
port 0/2/0:23
prefix 911
dial-peer voice 1000 voip
description **Incoming Call**
service session
rtp payload-type nse 99
rtp payload-type nte 100
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 11 pots
description LD 11 Digit via PRI
port 0/2/0:23
prefix 1
gateway
timer receive-rtp 1200
sip-ua
mwi-server ipv4:10.30.0.1 expires 3600 port 5060 transport udp
sip-server ipv4:10.30.0.1
telephony-service
no auto-reg-ephone
pin 6869
fxo hook-flash
max-ephones 144
max-dn 450
ip source-address 10.30.0.1 port 2000
auto assign 100 to 200
auto assign 5 to 25
service dnis dir-lookup
service dss
timeouts interdigit 2
timeouts busy 2
system message RJB WHOLESALE
url services http://phone-xml.berbee.com/menu.xml
cnf-file location flash:
load 7960-7940 P00308010200.loads
load ata ATA030204SCCP090202A.zup
time-format 24
voicemail 8999
max-conferences 20 gain -6
call-forward pattern .T
moh flash:/music-on-hold.au
web admin system name xxxxxx secret 5 $1$m58p$ugpgjOMzKUPV4FYKlifz1/
web admin customer name xxxxxx secret 5 $1$NCnY$ang63UsX2D7fV6j0fzYAN0
dn-webedit
transfer-digit-collect orig-call
transfer-system full-consult
transfer-pattern .T
transfer-pattern 9.T
secondary-dialtone 9
night-service code *1234
night-service day Sun 07:01 07:00
night-service day Mon 18:00 07:00
night-service day Tue 18:00 07:00
night-service day Wed 18:00 07:00
night-service day Thu 18:00 07:00
night-service day Fri 18:00 07:00
night-service day Sat 07:01 07:00
directory entry 1 94259681231 name FAX
create cnf-files version-stamp 7960 Jun 18 2013 22:13:43
ephone-dn-template  1
call-forward busy 1444
call-forward noan 1444 timeout 18
mwi on
allow watch
ephone-template  1
softkeys hold  Join Newcall Resume Select
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Redial Endcall Cfwdall Pickup Gpickup Callback
softkeys alerting  Acct Callback Endcall
softkeys connected  Hold Endcall Trnsfer Confrn Acct Flash Park
night-service bell
ephone-dn  1  dual-line
number 8700
label (425) 406-8700
ephone-dn  2  dual-line
number 8701
label (425) 406-8701
ephone-dn  3  dual-line
number 8702
label (425) 406-8702
ephone-dn  4  dual-line
number 8703
label (425) 406-8703
ephone-dn  5  dual-line
number 8704
label (425) 406-8704
ephone-dn  6  dual-line
number 8705
label (425) 406-8705
ephone-dn  7  dual-line
number 8706
label (425) 406-8706
ephone-dn  8  dual-line
number 8707
label (425) 406-8707
ephone-dn  9  dual-line
number 8708
label (425) 406-8708
ephone-dn  10  dual-line
number 8709
label (425) 406-8709
ephone-dn  11  dual-line
number 7353 secondary 4258217353
label FAX FORWARD
description FAX
mobility
snr 94259681231 delay 0 timeout 5 cfwd-noan 94259681231
call-forward max-length 10
corlist outgoing local
translation-profile outgoing 1
ephone  1
device-security-mode none
mac-address 000D.BC50.DBAF
type 7960
button  1:2 2:3
ephone  2
mac-address 000D.BC50.DD9D
button  1:2 2:3
ephone  3
mac-address 000D.BC50.E044
type 7960
button  1:1
ephone  4
mac-address 000D.BC50.F9E7
after-hours exempt
type 7960
no auto-line
button  1:11
night-service bell
ephone  5
mac-address 01AE.222A.EE4A
type 7960
button  1:4
ephone  6
mac-address 0014.A8AC.C98D
type 7960
button  1:5
ephone  7
mac-address 000D.BC50.DE0D
type 7960
button  1:10
ephone  8
mac-address 0014.A8AC.C81A
type 7960
button  1:6
ephone  9
mac-address 000D.BC50.F5C5
type 7960
button  1:7
ephone  10
mac-address 000D.BC50.F9E0
type 7960
button  1:8
ephone  11
mac-address 000D.BD35.431B
type 7960
button  1:9
ephone  12
mac-address 000D.28F3.3AD8
after-hours exempt
max-calls-per-button 2
username "fax" password 1234
type ata
no auto-line
pin 1234
night-service bell
ephone  25
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
login local
line aux 0
line 130
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
exec-timeout 0 0
privilege level 15
logging synchronous
login local
transport input all
line vty 5 15
exec-timeout 0 0
privilege level 15
logging synchronous
login local
transport input all
scheduler allocate 20000 1000
ntp server 131.107.13.100
ntp server 192.168.60.254
end
DEBUG:
cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=3603204709
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7353
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
Jun 19 08:35:20.152: //-1/02ACFAA28273/CCAPI/cc_api_call_setup_ind_common:
   Interface=0xC0D217D0, Call Info(
   Calling Number=3603204709,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7353(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=100, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
Jun 19 08:35:20.152: //-1/02ACFAA28273/CCAPI/ccCheckClipClir:
   In: Calling Number=3603204709(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Out: Calling Number=3603204709(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
Jun 19 08:35:20.152: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 19 08:35:20.152: :cc_get_feature_vsa malloc success
Jun 19 08:35:20.152:  cc_get_feature_vsa count is 1
Jun 19 08:35:20.152: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267828600,feature_id:4932
Jun 19 08:35:20.152: //2448142/02ACFAA28273/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=3603204709(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7353(TON=Unknown, NPI=Unknown))
Jun 19 08:35:20.152: //2448142/02ACFAA28273/CCAPI/cc_process_call_setup_ind:
   Event=0xC0A6AB18
Jun 19 08:35:20.152: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7353
Jun 19 08:35:20.156: //2448142/02ACFAA28273/CCAPI/ccCallSetContext:
   Context=0x6B253D90
Jun 19 08:35:20.156: //2448142/02ACFAA28273/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 2448142 with tag 100 to app "_ManagedAppProcess_Default"
Jun 19 08:35:20.156: //2448142/02ACFAA28273/CCAPI/ccCallProceeding:
Jun 19 08:35:20.156: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=20011, Params=0x6B243020, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
Jun 19 08:35:20.156: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
   Destination Pattern=7353$, Call
RJB-VOICE#ed Number=7353, Digit Strip=TRUE
   Redirect Number=, Display Info=Cell Phone   WA
   Account Number=, Final Destination Flag=TRUE,
   Guid=02ACFAA2-D7F2-11E2-8273-001B2AD6F6F0, Outgoing Dial-peer=20011
Jun 19 08:35:20.156: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=7353
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun 19 08:35:20.156: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0xC2B9DF58, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=3603204709,(Calling Name=Cell Phone   WA)(TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed),
   Called Number=7353(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20011, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Jun 19 08:35:20.156: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 19 08:35:20.156: :cc_get_feature_vsa malloc success
Jun 19 08:35:20.160:  cc_get_feature_vsa count is 2
Jun 19 08:35:20.160: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 19 08:35:20.160: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267827928,feature_id:4933
Jun 19 08:35:20.160: //2448143/02ACFAA28273/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
Jun 19 08:35:20.160: //2448143/02ACFAA28273/CCAPI/ccCallSetContext:
   Context=0x6B242FD0
Jun 19 08:35:20.160: //2448143/02ACFAA28273/CCAPI/cc_api_set_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=TRUE)
Jun 19 08:35:20.160: //-1/xxxxxxxxxxxx/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=103, Params=0x6B24C160, Progress Indication=NULL(0)
Jun 19 08:35:20.160: //-1/xxxxxxxxxxxx/CCAPI/ccCheckClipClir:
RJB-VOICE#TON=Unknown, NPI=Unknown, Screening=Not Screened, Presentation=Allowed)
   Destination Pattern=9.........., Called Number=94259681231, Digit Strip=TRUE
   Called Number=94259681231(TON=Unknown, NPI=Unknown),
   Guid=02ACFAA2-D7F2-11E2-8273-001B2AD6F6F0, Outgoing Dial-peer=103
Jun 19 08:35:20.160: //-1/xxxxxxxxxxxx/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=94259681231
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
Jun 19 08:35:20.160: //-1/xxxxxxxxxxxx/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0xC0D217D0, Interface Type=6, Destination=, Mode=0x0,
   Called Number=94259681231(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=103, Call Count On=FALSE,
Jun 19 08:35:20.160: :cc_get_feature_vsa malloc success
Jun 19 08:35:20.160:  cc_get_feature_vsa count is 3
Jun 19 08:35:20.160: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267826808,feature_id:4934
Jun 19 08:35:20.160: //2448144/02ACFAA28273/CCAPI/ccIFCallSetupReques
RJB-VOICE#tPrivate:
Jun 19 08:35:20.160: //2448144/02ACFAA28273/CCAPI/ccCallSetContext:
   Context=0x6B24C110
Jun 19 08:35:
RJB-VOICE#t
% Ambiguous command:  "t"
RJB-VOICE#20.160: //2448144/02ACFAA28273/CCAPI/cc_api_set_ssCTreRoutingNotSupported:
Jun 19 08:35:20.164: //2448143/02ACFAA28273/CCAPI/cc_api_update_call_info:
   Interface=0xC2B9DF58, Call Id=0x255B0F
Jun 19 08:35:20.164: //2448143/02ACFAA28273/CCAPI/cc_api_call_proceeding:
   Interface=0xC2B9DF58, Progress Indication=NULL(0)
Jun 19 08:35:20.168: //2448143/02ACFAA28273/CCAPI/cc_api_call_alert:
   Interface=0xC2B9DF58, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
   Call Entry(Retry Count=0, Responsed=TRUE)
Jun 19 08:35:20.168: //2448142/02ACFAA28273/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
Jun 19 08:35:20.168: //2448142/02ACFAA28273/CCAPI/ccSaveDialpeerTag:
Jun 19 08:35:20.200: //2448144/02ACFAA28273/CCAPI/cc_api_call_proceeding:
   Interface=0xC0D217D0, Progress Indication=NULL(0)
Jun 19 08:35:20.876: //2448144/02ACFAA28273/CCAPI/cc_api_call_alert:
   Interface=0xC0D217D0, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
Jun 19 08:35:20.880: //2448144/02ACFAA28273/CCAPI/cc_api_call_alert:
Jun 19 08:35:20.880: //2448142/02ACFAA28273/CCAPI/ccCallAlert:
RJB-VOICE#on=SIGNAL RINGBACK(1)
Jun 19 08:35:20.880: //2448142/02ACFAA28273/CCAPI/ccConferenceCreate:
   (confID=0xC2E13D3C, callID1=0x255B0E, gcid=2ACFAA2-D7F211E2-8273001B-2AD6F6F0, tag=0x0)
Jun 19 08:35:20.880: //2448144/02ACFAA28273/CCAPI/ccConferenceCreate:
   (confID=0xC2E13D3C, callID2=0x255B10, gcid=2ACFAA2-D7F211E2-8273001B-2AD6F6F0, tag=0x0)
   Conference Id=0xC2E13D3C, Call Id1=2448142, Call Id2=2448144, Tag=0x0
Jun 19 08:35:20.880: //2448142/02ACFAA28273/CCAPI/cc_api_bridge_done:
   Conference Id=0x30B, Source Interface=0xC0D217D0, Source Call Id=2448142,
   Destination Call Id=2448144, Disposition=0x0, Tag=0xFFFFFFFF
Jun 19 08:35:20.880: //2448144/02ACFAA28273/CCAPI/cc_api_bridge_done:
   Conference Id=0x30B, Source Interface=0xC0D217D0, Source Call Id=2448144,
   Destination Call Id=2448142, Disposition=0x0, Tag=0xFFFFFFFF
Jun 19 08:35:20.880: //2448142/02ACFAA28273/CCAPI/cc_generic_bridge_done:
   Call Entry(Conference Id=0x30B, Destination Call Id=2448144)
   Call Entry(Conference Id=0x30B, Destination Call Id=2448142)
Jun 19 08:35:20.880: //2448142/02ACFAA28273/CCAPI/cc_api_caps_ind:
   Destination Interface=0xC0D217D0, Destination Call Id=2448144, Source Call Id=2448142,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
Jun 19 08:35:20.880: //2448144/02ACFAA28273/CCAPI/cc_api_caps_ind:
   Destination Interface=0xC0D217D0, Destination Call Id=2448142, Source Call Id=2448144,
Jun 19 08:35:20.880: //2448144/02ACFAA28273/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7086)
Jun 19 08:35:20.880: //2448142/02ACFAA28273/CCAPI/cc_api_caps_ack:
RJB-VOICE#n Call Id=2448144, Source Call Id=2448142,
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5817)
Jun 19 08:35:20.880: //2448142/02ACFAA28273/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x30B, Call Id1=2448142, Call Id2=2448144
Jun 19 08:35:20.884: //2448144/02ACFAA28273/CCAPI/cc_api_voice_mode_event:
   Call Id=2448144
   Call Entry(Context=0x6B24C110)
Jun 19 08:35:20.884: //2448142/02ACFAA28273/CCAPI/cc_api_voice_mode_event:
   Call Id=2448142
   Call Entry(Context=0x6B253D90)
Jun 19 08:35:21.840: //2448144/02ACFAA28273/CCAPI/cc_api_call_cut_progress:
   Interface=0xC0D217D0, Progress Indication=INBAND(8), Signal Indication=INTERCEPT(2),
   Cause Value=0
   Call Entry(Responsed=TRUE)
Jun 19 08:35:21.840: //2448142/02ACFAA28273/CCAPI/ccCallProgIndProgress:
Jun 19 08:35:24.748: //2448143/02ACFAA28273/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0xC2B9DF58, Call Id=2448143
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
Jun 19 08:35:24.748: //2448143/02ACFAA28273/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
Jun 19 08:35:24.748: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=7353
Jun 19 08:35:24.748: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=7353, Called Number=7353, Calling Number=3603204709, Calling DN=-1 Calling Id=2448142,
   Redirect Number=94259681231, Redirect Reason=2
Jun 19 08:35:24.748: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 19 08:35:24.748: :cc_get_feature_vsa malloc success
Jun 19 08:35:24.748:  cc_get_feature_vsa count is 4
Jun 19 08:35:24.748: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267827704,feature_id:4935
Jun 19 08:35:24.748: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jun 19 08:35:24.748:  feature_vsa is C2C71B70,featname is 0
Jun 19 08:35:24.748:  cc_get_feature_vsa count is 5
Jun 19 08:35:24.748: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267825240,feature_id:4936
Jun 19 08:35:24.748: : Generating new featurevsa,inserting it
Jun 19 08:35:24.748:  feature call forward featname is 3
Jun 19 08:3
RJB-VOICE#5:24.748: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jun 19 08:35:24.748:  feature_vsa is C2C718D0,featname is 0
Jun 19 08:35:24.748:  cc_get_feature_vsa count is 6
Jun 19 08:35:24.748: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267826360,feature_id:4937
Jun 19 08:35:24.748: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 19 08:35:24.748: :cc_free_feature_vsa freeing C2C717F0
Jun 19 08:35:24.748:  vsacount in free is 5
Jun 19 08:35:24.748: //2448143/02ACFAA28273/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=2448143
Jun 19 08:35:24.748: //2448143/02ACFAA28273/CCAPI/ccCallDisconnect:
   Cause Value=19, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
Jun 19 08:35:24.752: //2448142/02ACFAA28273/CCAPI/ccConferenceDestroy:
   Conference Id=0x30B, Tag=0x0
Jun 19 08:35:24.752: //2448142/02ACFAA28273/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2448144, Disposition=0x0, Tag=0x0
Jun 19 08:35:24.752: //2448144/02ACFAA28273/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=2448142, Disposition=0x0, Tag=0x0
Jun 19 08:35:24.752: //2448142/02ACFAA28273/CCAPI/cc_generic_bridge_done:
Jun 19 08:35:24.752: //2448142/02ACFAA28273/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=103, Params=0x6B2406A0, Progress Indication=NULL(0)
Jun 19 08:35:24.752: //2448142/02ACFAA28273/CCAPI/ccCheckClipClir:
   Redirect Number=7353, Display Info=Cell Phone   WA
   Guid=0
RJB-VOICE#2ACFAA2-D7F2-11E2-8273-001B2AD6F6F0, Outgoing Dial-peer=103
Jun 19 08:35:24.752: //2448142/02ACFAA28273/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=0
   dest=94259681231
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=73
   cisco-rdn=7353
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=2   fwd_final_type =0
Jun 19 08:35:24.756: //2448142/02ACFAA28273/CCAPI/ccIFCallSetupRequestPrivate:
Jun 19 08:35:24.756: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Jun 19 08:35:24.756: :cc_get_feature_vsa malloc success
Jun 19 08:35:24.756:  cc_get_feature_vsa count is 6
Jun 19 08:35:24.756: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267827704,feature_id:4938
Jun 19 08:35:24.756: //2448175/02ACFAA28273/CCAPI/ccIFCallSetupRequestPrivate:
Jun 19 08:35:24.756: //2448175/02ACFAA28273/CCAPI/ccCallSetContext:
   Context=0x6B240650
Jun 19 08:35:24.756: //2448142/02ACFAA28273/CCAPI/ccSaveDialpeerTag:
Jun 19 08:35:24.756: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
Jun 19 08:35:24.756:  feature call forward featname is 3
Jun 19 08:35:24.756:  feature_vsa is C2C717F0,featname is 0
Jun 19 08:35:24.756:  cc_get_feature_vsa count is 7
Jun 19 08:35:24.756: :FEATURE_VSA attributes are: feature_name:0,feature_time:3267826136,feature_id:4939
Jun 19 08:35:24.756: : Generating new featurevsa,inserting it
Jun 19 08:35:24.756: //2448144/02ACFAA28273/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
Jun 19 08:35:24.756: //2448144/02ACFAA28273/CCAPI/cc_api_get_transfer_info:
Jun 19 08:35:24.760: //2448143/02ACFAA28273/C
RJB-VOICE#CAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC2B9DF58, Tag=0x0, Call Id=2448143,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
Jun 19 08:35:24.760: //2448143/02ACFAA28273/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
Jun 19 08:35:24.760: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 19 08:35:24.760: :cc_free_feature_vsa freeing C2C712B0
Jun 19 08:35:24.760:  vsacount in free is 6
Jun 19 08:35:24.760:  vsacount in free is 5
Jun 19 08:35:24.800: //2448175/02ACFAA28273/CCAPI/cc_api_call_proceeding:
Jun 19 08:35:24.804: //2448144/02ACFAA28273/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC0D217D0, Tag=0x0, Call Id=2448144,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Jun 19 08:35:24.804: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 19 08:35:24.804: :cc_free_feature_vsa freeing C2C71470
Jun 19 08:35:24.804:  vsacount in free is 4
Jun 19 08:35:24.900: //2448175/02ACFAA28273/CCAPI/cc_api_call_disconnected:
   Cause Value=1, Interface=0xC0D217D0, Call Id=2448175
   Call Entry(Responsed=TRUE, Cause Value=1, Retry Count=0)
Jun 19 08:35:24.900: //2448142/02ACFAA28273/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
Jun 19 08:35:24.900: //2448175/02ACFAA28273/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=2448175
Jun 19 08:35:24.900: //2448175/02ACFAA28273/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=1)
   Cause Value=1, Call Entry(Responsed=TRUE, Cause Value=1)
Jun 19 08:35:24.900: //2448175/02ACFAA28273/CCAPI/cc_api_get_transfer_info:
Jun 19 08:35:24.920: //2448175/02ACFAA28273/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC0D217D0, Tag=0x0, Call Id=2448175,
   Call Entry(Disconnect Cause=1, Voice Class Cause Code=0, Retry Count=0)
Jun 19 08:35:24.920: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 19 08:35:24.920: :cc_free_feature_vsa freeing C2C711D0
Jun 19 08:35:24.920:  vsacount in free is 3
Jun 19 08:35:24.920:  vsacount in free is 2
Jun 19 08:35:24.920: //2448142/02ACFAA28273/CCAPI/ccCallDisconnect:
   Cause Value=1, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
Jun 19 08:35:24.920: //2448142/02ACFAA28273/CCAPI/cc_api_get_transfer_info:
Jun 19 08:3
RJB-VOICE#5:24.940: //2448142/02ACFAA28273/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0xC0D217D0, Tag=0x0, Call Id=2448142,
Jun 19 08:35:24.940: //2448142/02ACFAA28273/CCAPI/cc_api_call_disconnect_done:
Jun 19 08:35:24.940: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Jun 19 08:35:24.940: :cc_free_feature_vsa freeing C2C70E50
Jun 19 08:35:24.940:  vsacount in free is 1
Jun 19 08:35:24.940:  vsacount in free is 0
V/R, Daniel Jones Cascade Technical Solutions IT Consulting, Specializing and Network and Systems Engineering
Everyone's tags (4)
5 REPLIES 5
Highlighted
Beginner
Bump... Anyone out there?
Highlighted
Hall of Fame Master
Re: Calls not forwarding to external number
Please post "debug isdn q931".
Note: please avoid leaving mid scale ratings when it was not even necessary. I had to delete my posting because of that.
If you are not ready to leave full rating, do not leave rating at all.
Highlighted
Beginner
I will get that debug for you tomorrow once I am back in the client's office. Thanks for the assistance in advance.
Highlighted
Beginner
RJB-VOICE#terminal monitor
RJB-VOICE#
Jun 21 15:19:39.090: %IPPHONE-6-REG_ALARM: Name=ATA7B9476C65F01 Load=ATA030204SCCP090202A.zup Last=Initialized
RJB-VOICE#
Jun 21 15:20:22.110: %IPPHONE-6-REG_ALARM: 24: Name=SEP001AE22AEE4A Load=8.1(2.0) Last=Phone-Reg-Rej
RJB-VOICE#
Jun 21 15:20:43.818: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 8701
Jun 21 15:20:43.818: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x014F callID = 0x80D0 switch = primary-ni interface = User
Jun 21 15:20:43.822: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x014F
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98386
                Exclusive, Channel 6
        Progress Ind i = 0x8183 - Origination address is non-ISDN
RJB-VOICE#
        Calling Party Number i = 0x0080, '8701'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '8003732546'
Jun 21 15:20:43.854: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x814F
Jun 21 15:20:44.550: ISDN Se0/2/0:23 Q931: RX <- PROGRESS pd = 8  callref = 0x814F
        Progress Ind i = 0x8288 - In-band info or appropriate now available
RJB-VOICE#
Jun 21 15:20:47.126: %ISDN-6-DISCONNECT: Interface Serial0/2/0:6  disconnected from 2532997156 , call lasted 161 seconds
RJB-VOICE#
Jun 21 15:20:47.126: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x014D
        Cause i = 0x8090 - Normal call clearing
Jun 21 15:20:47.150: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x814D
Jun 21 15:20:47.154: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x014D
RJB-VOICE#
Jun 21 15:20:50.298: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x014F
Jun 21 15:20:50.314: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x814F
Jun 21 15:20:50.314: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x014F
RJB-VOICE#
Jun 21 15:20:59.234: ISDN Se0/2/0:23 Q931: Applying typeplan for sw-type 0xD is 0x0 0x0, Calling num 8706
Jun 21 15:20:59.234: ISDN Se0/2/0:23 Q931: Sending SETUP  callref = 0x0150 callID = 0x80D1 switch = primary-ni interface = User
Jun 21 15:20:59.234: ISDN Se0/2/0:23 Q931: TX -> SETUP pd = 8  callref = 0x0150
                Standard = CCITT
        Channel ID i = 0xA98387
                Exclusive, Channel 7
RJB-VOICE#
        Calling Party Number i = 0x0080, '8706'
        Called Party Number i = 0x80, '2067624208'
Jun 21 15:20:59.254: ISDN Se0/2/0:23 Q931: RX <- CALL_PROC pd = 8  callref = 0x8150
Jun 21 15:20:59.854: ISDN Se0/2/0:23 Q931: RX <- ALERTING pd = 8  callref = 0x8150
Jun 21 15:21:00.334: ISDN Se0/2/0:23 Q931: RX <- CONNECT pd = 8  callref = 0x8150
Jun 21 15:21:00.334: %ISDN-6-CONNECT: Interface Serial0/2/0:6 is now connected to 2067624208 N/A
RJB-VOICE#
Jun 21 15:21:00.334: ISDN Se0/2/0:23 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x0150
RJB-VOICE#
Jun 21 15:21:06.750: %ISDN-6-DISCONNECT: Interface Serial0/2/0:6  disconnected from 2067624208 , call lasted 6 seconds
RJB-VOICE#
Jun 21 15:21:06.750: ISDN Se0/2/0:23 Q931: TX -> DISCONNECT pd = 8  callref = 0x0150
Jun 21 15:21:06.774: ISDN Se0/2/0:23 Q931: RX <- RELEASE pd = 8  callref = 0x8150
Jun 21 15:21:06.774: ISDN Se0/2/0:23 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x0150
RJB-VOICE#
Jun 21 15:21:09.278: %IPPHONE-6-REG_ALARM: Name=ATA7B9476C65F01 Load=ATA030204SCCP090202A.zup Last=Initialized
V/R,
Daniel Jones
Highlighted
Hall of Fame Master
There are two outgoing calls, one has been disconnected from the caller, the other has connected and then disconnected by caller.
Alos nothing indicates that these are forwarded calls so you should give more information on how you are testing things.
