Calls not going
anishktr2005
Beginner
Beginner
i have cisco BE6000 ,and i have a  Huwaei Esacpe cystem i need to
connect both system,i made a sip trunk between these two system ,now trunk
is showing up but calls are not going to huwaei pabx,in RTC tool showing
bad gataway
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
Look at the traces from both systems to try to pinpoint the issue and then take it from there.
java
if this helps, please rate
Mohammed al Baqari
VIP Advisor VIP Advisor
VIP Advisor
You can start with RTMT to generate SessionTrace and looking at the SIP messages for the failed call.
Recognize Your Peers
