Calls not received from specific area code
bfrancisco.home
I am very new with IP Telephony.
We are having an odd issue with calls not coming through from a specific area code.  Any incoming call from any other area code works fine.  Below is the debug isdn q931 output from the problem area code...
Feb  7 20:28:18.804: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8  callref = 0x4832
        Bearer Capability i = 0x9090A2
                Standard = CCITT
                Transfer Capability = 3.1kHz Audio
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18381
                Preferred, Channel 1
        Progress Ind i = 0x8283 - Origination address is non-ISDN
        Calling Party Number i = 0x2183, '312544----'
                Plan:ISDN, Type:National
        Called Party Number i = 0xA1, '283----'
Feb  7 20:28:18.808: ISDN Se0/0/0:23 Q931: Received SETUP  callref = 0xC832 callID = 0x6630 switch = primary-ni interface = User
Feb  7 20:28:18.828: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0xC832
        Channel ID i = 0xA98381
                Exclusive, Channel 1
Feb  7 20:28:18.828: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8  callref = 0xC832
Feb  7 20:28:18.896: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x4832
Feb  7 20:28:18.896: %ISDN-6-CONNECT: Interface Serial0/0/0:0 is now connected to 3125449765 N/A
Feb  7 20:28:53.361: ISDN Se0/0/0:23 Q931: RX <- DISCONNECT pd = 8  callref = 0x4832
        Cause i = 0x8490 - Normal call clearing
Feb  7 20:28:53.365: %ISDN-6-DISCONNECT: Interface Serial0/0/0:0  disconnected from 3125449765 , call lasted 34 seconds
Feb  7 20:28:53.365: ISDN Se0/0/0:23 Q931: TX -> RELEASE pd = 8  callref = 0xC832
Feb  7 20:28:53.385: ISDN Se0/0/0:23 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x4832
The call appears to be missing the alearting message.  Any ideas?
Thank you in advance
Logan Gaffney
Are you seeing the ALERTING message sent in the successful calls?
is this a CME or CUCM integration?
If CUCM, what is the conection back to CUCM H323/MGCP/SIP as you may need a combination of MTP Required/Inbound Fast Start
Once we know the connection, we can debug accordingly.
