Calls on FXO ports are disconnect after 20 sec
John Mayer
Hello everybodley
actually i have a problem on my FXO ports, all calls are automatically disconnected after 20 second
unfortunately its disconnected while users talking on the phone
i used custome cp-tone and supervisory disconnect on my FXOs
voice class custom-cptone AST
dualtone busy
frequency 425 425
cadence 500 500
dualtone ringback
frequency 425 425
cadence 1000 4000
dualtone disconnect
frequency 425 425
cadence 250 250
voice-port 0/1/0
supervisory disconnect dualtone mid-call
supervisory answer dualtone sensitivity high
supervisory custom-cptone AST
no battery-reversal
input gain 6
output attenuation 2
echo-cancel coverage 24
no vad
timeouts call-disconnect 2
timeouts wait-release 3
timing sup-disconnect 50
bearer-cap Speech
caller-id enable
does anybody have this problem before???
and another thing if i do not use supervisory disconnect, if caller on PSTN disconnect the call, router didnt understand the disconnect tone
acampbell
Try re-enabling battery reversal and loose the supervisory answer tones
voice-port 0/1/0
no supervisory answer dualtone sensitivity high
battery-reversal
Then retest
If you are still having issues try a debug of a failing call
debug vpm signal
This is a good link to read
http://docwiki.cisco.com/wiki/Cisco_IOS_Voice_Troubleshooting_and_Monitoring_--_FXO_Interfaces
Alex
Regards, Alex. Please rate useful posts.
acampbell
voice-port 0/1/0
battery-reversal
Then retest
debug vpm signal
Alex
hi
thanks for replay
actually try this but it work for 1 day and after that it disconnect again
so i try to remove all configuration under FXO ports, actuallt its work but incomming calls are disconnected after 1 min if they do not answer (or playing AA on it and caller disconnect when listen to incomming message)
