11-22-2015 01:35 PM - edited 03-17-2019 04:59 AM
I am facing a strange Problem with Huntgroups which are containing only CSF (Client Services Framework) devices.
The huntpilot is configured to forward calls on busy and no Answer to a voicemail-Pilot. Which is working when at least one csf device is registered. It does not work when no csf device is registered. Then a call for the Huntgroup is silently dropped. No busy tone or announcement.
We are using CUCM Version 10.5.2 SU2.
Any Hints are welcome!
Robert
Solved! Go to Solution.
11-22-2015 06:36 PM
Hi Robert,
It is a bug that you are running into:
https://tools.cisco.com/bugsearch/bug/CSCuv40352/?reffering_site=dumpcr
11-22-2015 06:36 PM
Hi Robert,
11-23-2015 12:25 AM
Hi Manish,
thanks for the Info!
It seems that there is another Workarond for this Problem (depends on the use case): Enable Call Queuing under the Hunt-Pilot and enable the setting "Route the call to this destination".
/Robert
11-23-2015 12:29 AM
Hi Robert,
Yes, that should work if the call algorithm fits your requirement.
Manish
