04-14-2011 09:58 AM - edited 03-16-2019 04:31 AM
I'm trying to use Calltracer 7.2.0 (http://www.myvoipsource.org/open-source-tools/calltracer/) with a CUCM 7.1.
I have followed the "readme" file to configure it, but it seems it doesn't work...
Has anyone used this software successfully and can help me?
Thanks in advance for your help!
Best regards.
04-19-2011 07:11 AM
anyone is using this software?
Regards.
09-22-2011 09:06 AM
I have tried the software with the latest CUCM version (8.6(x)), but it still doestn't work.
Unfortunately, I can't find other documentation than the "readme" in the .zip file, so I can't troubleshoot it.
Anyone can help me, please?
Regards.
09-23-2011 03:13 AM
finally, I was able to start the service of the software (INS-Calltracer).
Unfortunately, the software still does'n work.
In "calltracer.log", I can see this error:
org.myvoipsource.framework.axl.exception.AxlException: Error executing the http post request: AxlError: Authentication failture for axlUser -> check config!
The weird thing is that the AXL user and the CTI user in "config.yml" are the same, and that the same log file states:
[DEBUG] CtiConnectionProvider: Connected to provider
What's wrong?
TIA and regards.
09-19-2012 05:00 AM
did you ever get this application to work?
09-19-2012 06:11 AM
unfortunately, no.
Regards.
09-19-2012 06:38 AM
Thats a shame,
I like the idea it is phone service based and can look in the personal directory not just a global directory.
