Webcast -VXLAN BGP EVPNt
947
Camera is not paired with codec and may need a software upgrade. Please check camera to codec connection.
Al agregar un dispositivo de sala Room Kit Plus muestra el siguiente error:
Como puedo solucionarlo?
3 REPLIES 3
Highlighted
Explorer
Re: Camera is not paired with codec and may need a software upgrade. Please check camera to codec connection.
Did you ever get a resolution to this issue?  We are having the same problems.
Joe
Explorer
We resolved this by upgrading the codec, and powering down the quad camera and powering it back on...it then updated its firmware.
Joe
Contributor
Reboot, Downgrade, Upgrade.
Sometimes cameras got stuck in the upgrade process.
I my experience one of the action above usually solve the problem
Ask the Expert French- routing protocols
