Hello Experts,
Can anyone tell me and see if a single PLM handle multiple CUCM Publishers and Unity connection servers (mix of primary/secondary nodes). thanks in advance.
Solved! Go to Solution.
Yes, PLM can handle multiple servers, multiple versions, multiple clusters.
Brandon
Hi Cesar,
that is completely possible
https://supportforums.cisco.com/document/12229791/understanding-cisco-prime-license-managerplm
"Cisco Prime License Manager (Prime LM, formerly Cisco Enterprise License Manager) aligns with the Cisco Prime management suite of products. Cisco Prime LM offers new features and capabilities and adds support for Cisco Emergency Responder. Cisco Prime LM also supports multiple clusters and multiple versions of products, such as Cisco Unified CM versions 9. x and 10. x ."
(Rate if it helps)
JB
Brandon
Thank you for your prompt response
Hi Cesar,
(Rate if it helps)
JB
Happy to help.
Just in case you need an official cisco document see below
Cisco Prime License Manager (Prime LM, formerly Cisco Enterprise License Manager) aligns with the Cisco Prime management suite of products. Cisco Prime LM supports multiple clusters and multiple versions of products, such as Cisco Unified CM versions 10. x and 11. x.
Cisco Prime LM currently supports the following Cisco Collaboration applications:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab11/co...
JB
