01-05-2011 09:27 AM - edited 03-16-2019 02:41 AM
Hi, I have CUCM 7.1.3.30000-1 and recently the company bought some IP Phones 6911, bue I cannot add them to the telephony network. I've read that version of CUCM 8.0 (+) have support for that.
¿Does Cisco has a patch upgrade or a support pack?
I would like to use them but I do not want to upgrade to V8.0 right now.
Regards.
Solved! Go to Solution.
01-05-2011 09:49 AM
Hi Juan,
You will need to load the Device pack shown below to add support for the
6900 Series;
Products
Voice and Unified Communications
IP Telephony
Call Control
Cisco Unified Communications Manager (CallManager)
Cisco Unified Communications Manager Version 7.1
Unified Communications Manager/CallManager Device Packages
7.1(3.33031)
Cisco Unified CallManager Device Package 7.1.3(33031-1)
Release Notes
http://www.cisco.com/web/software/282074299/35230/cmterm-devicepack-7_1_3_33033-1_readme.html
Cheers!
Rob
EDIT: nice one Java! +5 buddy
01-05-2011 09:47 AM
Try installing the latest devpack for your CUCM release.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-05-2011 09:49 AM
Hi Juan,
6900 Series;
Products
IP Telephony
Call Control
7.1(3.33031)
Release Notes
Cheers!
Rob
01-05-2011 01:20 PM
Thank you so much javalen and rob.huffman for your answer I will try to load the device pack! I'll tell you later.
Five stars.
