Reports can be obtained through the CDR Analysis and Reporting tool. You can obtain the tool by going to the following screen:
Application >> Install Plug-in >> Click on CDR Analysis and Reporting
For notification (through SNMP trap) you need to use the Cisco Emergency Responder. Cisco Emergency Responder (Cisco ER) helps you manage emergency calls in your telephony network so that you can respond to these calls effectively and so that you can comply with local ordinances concerning the handling of emergency calls.
