09-29-2009 01:25 PM - edited 03-18-2019 10:38 AM
Does anyone know of a reason why a user can call a home/business phone from the US to Germany but not a cell phone in Germany (Just get a busy tone).
Digit Collection Timeout has been extended with no luck.
Dial Pattern is set to 9011T with no luck.
Have even removed all dial patterns and added a user defined 9[0-9]T with no luck...
Solved! Go to Solution.
09-29-2009 01:33 PM
Try setting sending-complete ?
Your call may be just correct and turn out to be a telco routing issue. Rare, but may happen.
So let's see the trace first.
09-29-2009 01:28 PM
Can you post a debug isdn q931 and a debug voice dialpeer inout of a failed call.
09-29-2009 01:42 PM
Will do tomorrow as I am not in the server room.
FYI,
I tried to call two separate cell phones in Germany with same results.
Local numbers are 13 digits and cell phones are 12...my head hurts trying to figure this out..
09-29-2009 01:32 PM
But let's see the trace first.
09-29-2009 01:33 PM
09-30-2009 12:48 AM
Do you use the 9@ NANP as this will be more explicit from the 9011T pattern- maybe the 9@ for Germany is fixed for 12 digits.Create an exact route pattern for the Germany Mobile and test again so you bypass any other route - what does the q931 show?
09-30-2009 08:52 AM
Hi All,
I hope I am doing this correctly.
Here is the q931
Called Party Number i = 0x91, '0114917278xxxxx'
Plan:ISDN, Type:International
012406: Sep 30 16:45:21.838: ISDN Se0/2/0:23 Q931: RX <- STATUS pd = 8 callref = 0x818E
Cause i = 0x80E3A1 - Information element not implemented
Call State i = 0x01
012407: Sep 30 16:45:21.938: ISDN Se0/2/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x818E
Cause i = 0x809C - Invalid number format (incomplete number)
09-30-2009 08:55 AM
That's not correct:
Known problem, router is incorrectly setting pan/type when it sees 011
Configure
int s0/2/0:23
isdn map address . plan unknown type unknown
09-30-2009 09:01 AM
Please forgive my ignorance..
I am not running any routers.
I have 2 switches and then the Pix.
Could you please clarify?
Never-mind, I believe you are talking about the router coming in then going to the PBX.? I think.. ;)
09-30-2009 09:07 AM
Yes, the voice gateway is actually a router.-
09-30-2009 05:27 PM
Problem Solved!
Thank you very much!
