Can i connect my home Land Line (RJ11) to FXO port on Cisco router and test some voice stuff
Ibrahim Jamil
Level 6
Level 6
11 Replies 11
balaji.bandi
yes FXO support incoming and out going calls
BB
Yes You can connect and do the testing.
Response Signature
Yes
Response Signature
Ibrahim Jamil
Level 6
Level 6
Hi all
Pls a decent configuration example to follow it up
thanks all
Below example is one which i use in my region.
voice class custom-cptone 1
dualtone disconnect
frequency 427
cadence 300 300
voice-port 0/1/0
supervisory custom-cptone 1
ring number 3
cptone OM
connection plar opx 1000
caller-id enable
voice hunt-group 4 parallel
list 8414,8428,8413,8418
pilot 1000
Response Signature
Hi nithin
thanks
i need to understand the syntax how it looks like  , i never dealt with FXO/FXS , we are using CUBE
thanks
Look at @Nithin Eluvathingal example and modify it to fit the area of the world where your located. Otherwise there are plenty of configuration documentation and examples available if you put a couple of minutes in on any search engine of your choice.
Response Signature
Hi Balaji
Thanks for Helping , mate , do u have decent video config example?
In what sense do you mean video in combination with FXO?
Response Signature
How to Configure an FXO Port to Ring VoIP Phone on CUBE and CUCM =================================================== FXO Voice Port Configuration * Unlike a T1 Card there is no configuration needed after FXO Card installation * Each FXO port will need to be configured and there are several ...
5-2 Configuring FX0 Connectivity on a Cisco 2811
