Can I reorder the 8831 softkeys? ("apps", "contacts", and "msgs")
jonathanwalton
Is there a way to change the order of the softkeys on an 8831?  The Softkey Template Configuration doesn't allow me to move the "Apps", "Contacts", and "Msgs" softkeys around.
I'm running CUCM v9.1
jdhoefler
Has anyone found a solution to this, I just ran into the same problem.
Thanks in advance.
I never did.
hi ,
There was an enhancement request filed for  this (CSCuo50166)  .  You can get in touch with your local Account team with your business requirement to have this fixed.
Karthik Sivaram
