Is this your call flow?
IP Phone ----- Voice GW --- PRI -- PSTN?
In this case, I dont think the T1/E1 has anything to do with your oneway/no way audio..
When you make a call from IP Network to the PSTN out the PRI, DSPs are used to xmit the same out the PRI.
g711u/g711a = 15 MIPS per call
g729a/g729ab = 30 MIPS per call
g729/g729b = 40 MIPS per call
So if you have a phone talking G711, we would use 15 MIPS from the DSP. PVDM2-16(15 x 16 G711 calls) has 240 MIPS.
Do we have a routin issue?.. Do one thing...
Make a test call, collect
show voip rtp connection
show call active voice brief
debug isdn q931
debug mgcp packets ( if its a mgcp gw)
debug ccsip messages ( if its a sip gw)
debug h225 asn1(h323)
debug h245 asn1 (h323)
/divin
PS: Rate useful posts!
