Can I Upgrade IOS in Router With This Configuration.
roopesh.n
Hi All,
We are using Cisco Voice router 3700 with 12.3 ios .So Some Commands related to SIP is not working with this Version of IOS. So please suggest which version will support all the commands related to SIP and Which is the higst version available for this model router. Can i upgrade with below hardware. Please find the Details for Hardware configuration.
oh-rt2#sh version
IOS (tm) 3700 Software (C3745-ADVIPSERVICESK9-M), Version 12.3(26), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Mon 17-Mar-08 17:42 by dchih
ROM: System Bootstrap, Version 12.2(8r)T2, RELEASE SOFTWARE (fc1)
oh-rt2 uptime is 1 week, 16 hours, 16 minutes
System image file is "flash:c3745-advipservicesk9-mz.123-26.bin"
--More--         A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco 3745 (R7000) processor (revision 2.0) with 248832K/13312K bytes of memory.
Processor board ID JPE084610D9
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2, 2048KB L3 Cache
Channelized E1, Version 1.0.
Bridging software.
X.25 software, Version 3.0.0.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
86 Serial network interface(s)
4 Serial(sync/async) network interface(s)
3 Channelized E1/PRI port(s)
8 Voice FXO interface(s)
DRAM configuration is 64 bits wide with parity disabled.
151K bytes of non-volatile configuration memory.
31360K bytes of ATA System CompactFlash (Read/Write)
Configuration register is 0x101
--More--
oh-rt2#sh flash
-#- --length-- -----date/time------ path
1     23051120 Dec 13 2008 13:06:00 +05:30 c3745-advipservicesk9-mz.123-26.bin
2       214630 Mar 1 1993 05:44:24 +05:30 crashinfo_19930301-001424
3        58241 Mar 1 1993 12:11:22 +05:30 crashinfo_19930301-064122
4        19475 Mar 1 1993 05:30:06 +05:30 crashinfo_19930301-000007
5       205921 Mar 14 1993 03:15:26 +05:30 crashinfo_19930313-214526
6       207156 Mar 1 1993 06:40:24 +05:30 crashinfo_19930301-011025
7        58245 Mar 1 1993 20:45:44 +05:30 crashinfo_19930301-151544
8        19544 Mar 1 1993 05:30:08 +05:30 crashinfo_19930301-000009
9       196289 Mar 3 1993 09:06:26 +05:30 crashinfo_19930303-033626
10      252692 Mar 2 1993 20:52:12 +05:30 crashinfo_19930302-152213
11      222225 Mar 1 1993 10:14:28 +05:30 crashinfo_19930301-044428
12      202269 Mar 22 1993 03:23:44 +05:30 crashinfo_19930321-215344
13       56620 Mar 3 1993 04:09:44 +05:30 crashinfo_19930302-223945
7147520 bytes available (24788992 bytes used)
oh-rt2#
Roopesh
Hi Roopesh,
You can delete the crash info files from the flash. That would give you some space. Also, the size of the IOS may not exceed 66895008 bytes
Dass
Please rate useful posts :)
7 Replies 7
Jaime Valencia
Use the IOS command lookup tool to find what IOS release has the commands you need
http://tools.cisco.com/Support/CLILookup/cltSearchAction.do
Then use the IOS advisor to find the right IOS and reqs for your HW
http://tools.cisco.com/Support/Fusion/FusionHome.do
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Dass Prakash R
Hi Roopesh,
You can positively use the latest release of IOS - 15.2 (3)
Dass
HI Dass,
Thanks for the reply.
Can i Upgrade to 15.2 with Same Configuration . Ram ,flash, CPU will it support 15.2??
thanks
Roopesh
Yes for a 2 GB RAM you can upgrade it to 15.2(3). Ensure you have enough Flash storage for the IOS
Dass
Hi Dass,
In flash I have
7147520 bytes available (24788992 bytes used).Is it enough ?
Roopesh
Hi Roopesh,
Dass
Thanks Dass
