Can I use ordinary access point for cisco 7921 wireless Phone?
wahidayat007
I want to deploy Cisco ip 7921 wireless phone, Apart from cisco controller and cisco access point, Can I use Net gear, Dlink & Motorola access points to install 7921 wireless phone.
Any detail help will be appreciated.
Michael Odom
Level 4
Level 4
You should, the 7921 phone follows the 802.11 standards very well, and supports most of the security protocols (I have some using WPA2 with 802.1x).
I would, however, highly recommend using an AP that supports WMM, and this may not be available on some of the SOHO boxes.
