01-12-2012 02:30 PM - edited 03-16-2019 08:59 AM
Hi All,
I has had problem to registering ATAS 187 on Cisco 7.1.3, and after looking on the Cisco Support Page I found that there is a QED File and Firmware for Version el CUCM Above 6.X
Just look at this link.
http://www.cisco.com/web/software/282074215/64021/cmterm-ata187-9-2-3-1-readme.html
It does not say's "Device Enabler" Like the other formwares for phones, I would like to know if I can download the 2 files and then start to registering atas 187 on my CUCM 7.1.3 without Problems.
Can someone help me to solve this, Will this work?
Solved! Go to Solution.
01-12-2012 04:52 PM
If you're running 7.1(3) you do not meet the minimum requirements, all the info is on the data sheet which is available on CCO
Cisco UCM Version Compatibility
• Cisco UCM Versions 7.1.5, 8.0.2, or higher
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-12-2012 02:54 PM
Well, I have another question about this. It it for the process of installing.
Y have a cluster with 5 servers CUCM 7.1.3, One Publisher 4 Subs. And I know I have to install the QED File before thw firmware
¿Do I have to instal de QED File on every node? (Before the firmware).
After the install, I know I have tho restart the TFTP en the Publisher, but...
Do I have to restar every CallManager Process en every Node?
I was wondering I would restart Call Manager service on the 10.0.0.5 wait for it to get up, after that, in the 10.0.0.6... wait, then 10.0.0.7... wait and so on.
Is that the correcto way to proceed?
thank you very mucho for sharing your knowledge.
01-12-2012 04:52 PM
java
01-13-2012 08:25 AM
Thanks, Javalenc, so the asnwer here is "No u' definitively can not install". right?
Would u' please help me the those adicionals concernings (is for another phone QED and firmware).
Regards!
