can make only one outbound call and then busy tone - CME using FXO por
rajkamath
Good day,
Trying to get a outbound call working through a single line connected to fxo port. first call always works, ( have tested with international, national and mobile ). i hang up and try calling again, it gives a busy tone till i reload the router.  Anything to check or try to get that sorted out. Given below is the debug logs that showed up on the router when dialing out. Voice ports are showing on hook . sh run attached.
Router#sh voice port su
Router#sh voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/0           --  fxo-ls      up    dorm idle     on-hook  y
0/2/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/2           --  fxo-ls      up    dorm idle     on-hook  y
0/2/3           --  fxo-ls      up    dorm idle     on-hook  y
PWR FAILOVER PORT        PSTN FAILOVER PORT
Router#
445: *Oct 17 13:23:48.853: //50/C47E15DC8068/
------------------ Cover Buffer ---------------
Search-key       = 801:0508363235:50
  Timestamp      = *Oct 17 13:23:48.251
  CallID         = 50
  Peer-CallID    = NA
  Correlator     = NA
  Called-Number  = 0508363235
  Calling-Number = 801
  SIP CallID     = 00df1d88-6a200007-40dbbd29-2451d9cc@10.90.80.3
  SIP SessionID  =
  GUID           = C47E15DC8068
416: *Oct 17 13:23:48.251: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0508363235@10.90.80.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.90.80.3:5060;branch=z9hG4bK47f93dda
From: "Basel Thaher " <sip:801@10.90.80.1>;tag=00df1d886a20001c31ce4143-3531f195
To: <sip:0508363235@10.90.80.1>
Call-ID: 00df1d88-6a200007-40dbbd29-2451d9cc@10.90.80.3
Max-Forwards: 70
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=0000000000000000000000000000        0000
Date: Mon, 17 Oct 2022 13:23:47 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7811/14.1.1
Contact: <sip:1A694-BD@10.90.80.3:5060;transport=udp>;+u.sip!devicename.ccm.cisc        o.com="SEP00DF1D886A20"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Basel Thaher " <sip:801@10.90.80.1>;party=calling;id-type=subs        criber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-        cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-        cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-        8.5.1
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Authorization: Digest username="801",realm="",uri="sip:0508363235@10.90.80.1;use        r=phone",response="d3cc0a64befe157d795b079ad6492ec0",nonce="17175C020025C2A1",cn        once="23389a8e",qop=auth,nc=00000002,algorithm=MD5
Content-Length: 345
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 28297 0 IN IP4 10.90.80.3
s=SIP Call
b=AS:4064
t=0 0
m=audio 24366 RTP/AVP 0 8 116 18 101
c=IN IP4 10.90.80.3
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
420: *Oct 17 13:23:48.251: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_NONE, Next State = STATE_IDLE, Current Sub-State = STATE_NO        NE, Next Sub-State = STATE_NONE
421: *Oct 17 13:23:48.252: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Matched Dialpeer:        Dir:Inbound, Peer-Tag:  40001
422: *Oct 17 13:23:48.252: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Offer-Answer: Event        = E_SIP_INVITE_SDP_RCVD, Current State = S_SIP_EARLY_DIALOG_IDLE, Next State =        S_SIP_EARLY_DIALOG_OFFER_RCVD
423: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_        IWF_EV_RCVD_SDP, Current State = S_SIP_IWF_SDP_IDLE, Next State = S_SIP_IWF_SDP_        RCVD_AWAIT_PEER_EVENT
424: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Media Stream Param        eters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec =        g711ulaw, Negotiated DTMF Type = inband-voice, Stream Index =  1
425: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_update_inte        rface_cac_resource (0)
426: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_allocate_        port (8024)
427: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Media Stream Param        eters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec =        g711ulaw, Negotiated DTMF Type = inband-voice, Stream Index =  1
428: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_call_setup_        ind_with_callID (0)
429: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_IDLE, Next State = STATE_RECD_INVITE, Current Sub-State = S        TATE_NONE, Next Sub-State = STATE_NONE
430: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 17 Oct 2022 13:23:48 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-17.3.5
Session-ID: 00000000000000000000000000000000;remote=4dfbd3e200105000a00000df1d88        6a20
Content-Length: 0
431: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Call Disconnect: I        nitiated at: 0x260070A, Originated at:0x260070B, Cause Code = 28
432: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_update_inte        rface_cac_resource (0)
433: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Event-Action: Event        = SIPSPI_EV_CC_CALL_DISCONNECT, Current State = STATE_RECD_INVITE
434: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_RECD_INVITE, Next State = STATE_DISCONNECTING, Current Sub-        State = STATE_NONE, Next Sub-State = STATE_NONE
435: *Oct 17 13:23:48.256: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_DISCONNECTING, Next State = STATE_DISCONNECTING, Current Su        b-State = STATE_NONE, Next Sub-State = STATE_NONE
436: *Oct 17 13:23:48.256: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 484 Address Incomplete
To: <sip:0508363235@10.90.80.1>;tag=18523C8-EEF
CSeq: 101 INVITE
Reason: Q.850;cause=28
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=0cb9ec974c0e5853b09e6ceb62c6        3c7c
Content-Length: 0
438: *Oct 17 13:23:48.356: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0508363235@10.90.80.1;user=phone SIP/2.0
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=4dfbd3e200105000a00000df1d88        6a20
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
439: *Oct 17 13:23:48.356: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Event-Action: Event        = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_DISCONNECTING
440: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_release_p        ort (8024)
441: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_call_discon        nect_done (0)
442: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_DISCONNECTING, Next State = STATE_DEAD, Current Sub-State =        STATE_NONE, Next Sub-State = STATE_NONE
443: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Error: sipSPIFlush        DeferredQueue: Invalid deferredQueue
444: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_release_p        ort (8024)
Router#
Router#sh voice
Router#sh voice po
                                           IN       OUT
With a single line there is really no point in having a trunk group, especially not with multiple FXO ports added to it. If you do want to keep the trunk group you should remove the other FXO ports from it, leaving only the operational FXO port in the trunk group. That would in essence be the same as having one single FXO port on the dial peers.
Response Signature
18 Replies 18
From what I can see your call is not successful as you get Cause Code = 28, this equates to invalid number format (address incomplete).
Response Signature
As on your other post where you wrote that you have attached the running configuration there are no attached file on this post either. Please share your running configuration.
Response Signature
Can you post your dial-peers and any digit manipulation (like voice translation profiles or sip profiles)? I see the SIP side of the call, but not the analog side. So it is hard to tell how the gateway is egressing the call.
Maren
These are the dial peers i added. I havent used any digit manipulation. Anything else to try on the system .
dial-peer voice 1 pots
trunkgroup FXO
destination-pattern 90[234679].......
prefix 0
dial-peer voice 2 pots
trunkgroup FXO
destination-pattern 9[2-8][0-9][1-9]....
forward-digits 7
dial-peer voice 5 pots
trunkgroup FXO
destination-pattern 900T
prefix 00
dial-peer voice 7 pots
trunkgroup FXO
destination-pattern 9800T
prefix 800
dial-peer voice 6 pots
trunkgroup FXO
destination-pattern 9600T
prefix 600
dial-peer voice 3 pots
trunkgroup FXO
destination-pattern 905[0456].......
prefix 05
rajkamath
sh run attached. There is no translation rule applied. is that required ? The first call, local , or mobile or even international rings without any issues. Once you hung up , then the next call is possible is only if you reload the router.
As you use a trunk group on your dial peers for your FXO ports do you know if all of your ports in the trunk group are operational?
Apart from this what do you mean by this “call working through a single line connected to fxo port” as you have grouped your FXO ports into a trunk group?
If you only have one operational FXO port you should remove the other, non operational, ports from the trunk group or use a single port on your dial peers.
Response Signature
@rajkamath If you dial 0508363235, it finds no match in your voice gateway.
But if you dial the number as 90508363235, then it would match dial peer 3 shown below.
trunkgroup FXO
prefix 05
The resulting dialed number that leaves the FXO port would then be 0508363235.
The number should be 0508363235. It worked on the first call that the phone does. So confused. Will certainly give that a shot and post back.
That didnt help. also tried taking the trunk group off and using port numbers one by one. still gives busy tone. reload the box and dial out. works properly for a single call and back to square one again.
That may be an IOS issue then. Have you done a bug search on your IOS version?
One small correction on your reply. The resulting number would be 0508363235 as the 905 would be consumed on the dial peer as they are explicitly matched. This is because a POTS dial peer will per default remove anything that is specifically matched on the dial peer and 905 is, but 0456 is not as they are within square brackets. In essence what the dial peer does is to drop the leading 9 as it prefix’s 05 back to the called number to result in 0508363235.
Response Signature
Roger, Thanks for the correction. You are right. I totally forgot about how that worked until you reminded me. I went ahead and edited my response.
rajkamath
testing it with a single analogue line at the moment . should i take that trunk group off since its a single line.  first timer. so its been a mix of reading and seeking guidance on how and what to do and what not to .thanks again.
why does it work on the first instance and then it goes down.
Try taking the trunk group off and test with one port at a time. Instead of "trunk-group FXO" just use "port 0/1/0" and test again.
If that doesn't work, then try "port 0/1/1" and so on.
