can make only one outbound call and then busy tone - CME using FXO por
rajkamath
Good day,
Trying to get a outbound call working through a single line connected to fxo port. first call always works, ( have tested with international, national and mobile ). i hang up and try calling again, it gives a busy tone till i reload the router.  Anything to check or try to get that sorted out. Given below is the debug logs that showed up on the router when dialing out. Voice ports are showing on hook . sh run attached.
Router#sh voice port su
Router#sh voice port summary
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/1/0           --  fxo-ls      up    dorm idle     on-hook  y
0/1/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/0           --  fxo-ls      up    dorm idle     on-hook  y
0/2/1           --  fxo-ls      up    dorm idle     on-hook  y
0/2/2           --  fxo-ls      up    dorm idle     on-hook  y
0/2/3           --  fxo-ls      up    dorm idle     on-hook  y
PWR FAILOVER PORT        PSTN FAILOVER PORT
Router#
445: *Oct 17 13:23:48.853: //50/C47E15DC8068/
------------------ Cover Buffer ---------------
Search-key       = 801:0508363235:50
  Timestamp      = *Oct 17 13:23:48.251
  CallID         = 50
  Peer-CallID    = NA
  Correlator     = NA
  Called-Number  = 0508363235
  Calling-Number = 801
  SIP CallID     = 00df1d88-6a200007-40dbbd29-2451d9cc@10.90.80.3
  SIP SessionID  =
  GUID           = C47E15DC8068
416: *Oct 17 13:23:48.251: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0508363235@10.90.80.1;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.90.80.3:5060;branch=z9hG4bK47f93dda
From: "Basel Thaher " <sip:801@10.90.80.1>;tag=00df1d886a20001c31ce4143-3531f195
To: <sip:0508363235@10.90.80.1>
Call-ID: 00df1d88-6a200007-40dbbd29-2451d9cc@10.90.80.3
Max-Forwards: 70
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=0000000000000000000000000000        0000
Date: Mon, 17 Oct 2022 13:23:47 GMT
CSeq: 101 INVITE
User-Agent: Cisco-CP7811/14.1.1
Contact: <sip:1A694-BD@10.90.80.3:5060;transport=udp>;+u.sip!devicename.ccm.cisc        o.com="SEP00DF1D886A20"
Expires: 180
Accept: application/sdp
Allow: ACK,BYE,CANCEL,INVITE,NOTIFY,OPTIONS,REFER,REGISTER,UPDATE,SUBSCRIBE,INFO
Remote-Party-ID: "Basel Thaher " <sip:801@10.90.80.1>;party=calling;id-type=subs        criber;privacy=off;screen=yes
Supported: replaces,join,sdp-anat,norefersub,resource-priority,extended-refer,X-        cisco-callinfo,X-cisco-serviceuri,X-cisco-escapecodes,X-cisco-service-control,X-        cisco-srtp-fallback,X-cisco-monrec,X-cisco-config,X-cisco-sis-7.0.0,X-cisco-xsi-        8.5.1
Allow-Events: kpml,dialog
Recv-Info: conference
Recv-Info: x-cisco-conference
Authorization: Digest username="801",realm="",uri="sip:0508363235@10.90.80.1;use        r=phone",response="d3cc0a64befe157d795b079ad6492ec0",nonce="17175C020025C2A1",cn        once="23389a8e",qop=auth,nc=00000002,algorithm=MD5
Content-Length: 345
Content-Type: application/sdp
Content-Disposition: session;handling=optional
v=0
o=Cisco-SIPUA 28297 0 IN IP4 10.90.80.3
s=SIP Call
b=AS:4064
t=0 0
m=audio 24366 RTP/AVP 0 8 116 18 101
c=IN IP4 10.90.80.3
b=TIAS:64000
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:116 iLBC/8000
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
420: *Oct 17 13:23:48.251: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_NONE, Next State = STATE_IDLE, Current Sub-State = STATE_NO        NE, Next Sub-State = STATE_NONE
421: *Oct 17 13:23:48.252: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Matched Dialpeer:        Dir:Inbound, Peer-Tag:  40001
422: *Oct 17 13:23:48.252: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Offer-Answer: Event        = E_SIP_INVITE_SDP_RCVD, Current State = S_SIP_EARLY_DIALOG_IDLE, Next State =        S_SIP_EARLY_DIALOG_OFFER_RCVD
423: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/FSM/IWF: Event = E_SIP_        IWF_EV_RCVD_SDP, Current State = S_SIP_IWF_SDP_IDLE, Next State = S_SIP_IWF_SDP_        RCVD_AWAIT_PEER_EVENT
424: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Media Stream Param        eters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec =        g711ulaw, Negotiated DTMF Type = inband-voice, Stream Index =  1
425: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_update_inte        rface_cac_resource (0)
426: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_allocate_        port (8024)
427: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Media Stream Param        eters: Stream Type = voice-only, Stream State = STREAM_ADDING Negotiated Codec =        g711ulaw, Negotiated DTMF Type = inband-voice, Stream Index =  1
428: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_call_setup_        ind_with_callID (0)
429: *Oct 17 13:23:48.253: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_IDLE, Next State = STATE_RECD_INVITE, Current Sub-State = S        TATE_NONE, Next Sub-State = STATE_NONE
430: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 17 Oct 2022 13:23:48 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-17.3.5
Session-ID: 00000000000000000000000000000000;remote=4dfbd3e200105000a00000df1d88        6a20
Content-Length: 0
431: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Call Disconnect: I        nitiated at: 0x260070A, Originated at:0x260070B, Cause Code = 28
432: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_update_inte        rface_cac_resource (0)
433: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Event-Action: Event        = SIPSPI_EV_CC_CALL_DISCONNECT, Current State = STATE_RECD_INVITE
434: *Oct 17 13:23:48.255: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_RECD_INVITE, Next State = STATE_DISCONNECTING, Current Sub-        State = STATE_NONE, Next Sub-State = STATE_NONE
435: *Oct 17 13:23:48.256: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_DISCONNECTING, Next State = STATE_DISCONNECTING, Current Su        b-State = STATE_NONE, Next Sub-State = STATE_NONE
436: *Oct 17 13:23:48.256: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 484 Address Incomplete
To: <sip:0508363235@10.90.80.1>;tag=18523C8-EEF
CSeq: 101 INVITE
Reason: Q.850;cause=28
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=0cb9ec974c0e5853b09e6ceb62c6        3c7c
Content-Length: 0
438: *Oct 17 13:23:48.356: //50/C47E15DC8068/CUBE_VT/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0508363235@10.90.80.1;user=phone SIP/2.0
Session-ID: 4dfbd3e200105000a00000df1d886a20;remote=4dfbd3e200105000a00000df1d88        6a20
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
439: *Oct 17 13:23:48.356: //50/C47E15DC8068/CUBE_VT/SIP/FSM/Event-Action: Event        = SIPSPI_EV_NEW_MESSAGE, Current State = STATE_DISCONNECTING
440: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_release_p        ort (8024)
441: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: cc_api_call_discon        nect_done (0)
442: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/FSM/SPI-State-Change: C        urrent State = STATE_DISCONNECTING, Next State = STATE_DEAD, Current Sub-State =        STATE_NONE, Next Sub-State = STATE_NONE
443: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/MISC/Error: sipSPIFlush        DeferredQueue: Invalid deferredQueue
444: *Oct 17 13:23:48.357: //50/C47E15DC8068/CUBE_VT/SIP/API: voip_rtp_release_p        ort (8024)
Router#
Router#sh voice
Router#sh voice po
                                           IN       OUT
18 Replies 18
With a single line there is really no point in having a trunk group, especially not with multiple FXO ports added to it. If you do want to keep the trunk group you should remove the other FXO ports from it, leaving only the operational FXO port in the trunk group. That would in essence be the same as having one single FXO port on the dial peers.
Response Signature
With the trunk group configuration you have the call would flip between your FXO ports depending on how long they have been idle. Meaning that the call would not go to the operational FXO port on the second call as that then is the least idle as it just handled a call. As I and @TechLvr stated start by using a single port, easiest would be to use the port command on your dial peers or if you do not want to be easy remote all, but the one port, from your trunk group.
Response Signature
rajkamath
that worked. been under the impression that since they are not being utilized, it doesn't matter. just added single port to the trunkgroup and calls are flowing through without any issues.
Thanks again.
Glad to hear that.
Response Signature
