Can option 150 be used for more than 1 TFTP server for different items?
hankej
I am wondering if we can use Option 150 in our routers to point to more than 1 TFTP server.  What we wondering is to have the Option 150 to point to our CUCM servers and to also point to our Singelwire Informacast server.  We need to reach our TFTP server on the Informacast server for our Atlas Zone Controllers, to the Zone controller can download the IpSpeakerConfig.cfg file.
I don't know if this is how it should be setup or not, but when I go to the IP address of the Zone controller it says:
TFTP servers reported by DHCP option 150:
  • TFTP Server at <CUCM Server>
    • checked 3 times.
    • TFTP server responded
    • 'IPSpeaker00119000577c.cfg' not on server
    • 'IPSpeaker.cfg' not on server
    • 'InformaCastSpeaker00119000577c.cfg' not on server
    • 'InformaCastSpeaker.cfg' not on server
If I put the Informacast server in the Option 150, will the zone controller try this TFTP server after it can't find the information on my CUCM server?
Thank you
amansin74
Not sure about Option 150
But I am wondering, IF you can use separate range of IP addresses for IP Phones, then you can configure separate DHCP pool for IP Phones or vice versa for Your informacast server.
In separate dhcp pool you can use separate TFTP server.
“If you have knowledge, let others light their candles in it.”
