can single Expressway C+E support multiple clusters and domains
We are looking to implement the Expressway MRA solution for external jabber clients and B2B video.
We have multiple clusters with different toplevel domains on each cluster. Some clusters might have more domains.
Can we implement one set of Expressway C + E cluster and support multiple clusters and here by preserve resources in the VMware and only implement 1 set of certificates.
According to the MRA deployment guide, there is the "deployments", but will it support multiple toplevel domain.
Any input would be appreciated.
7 REPLIES 7
VIP Mentor
Can you attach a high level
Can you attach a high level diagram so we can get an accurate description of what your environment looks like
Please rate all useful posts
Highlighted
Could be something like this:
VIP Mentor
Martin, no this is not
Martin, no this is not supported..Expressway remote access is limited to one customer domain per cluster. You can only support multiple cucm, IM&P clusters on a single expressway if the domain is uniform. You will need multiple expressway clusters for this
Participant
Hi Ayodeji,  Is this type of
Hi Ayodeji,
Is this type of deployment support.
Also off the topic question, can I have a top level domain(example.com) and sub-domain(staging.example.com) form a peer relationship in im & presence servers.
As per Cisco 2 sub-domains apart of the same top-level domain can form a peer relationship.
Thanks.
Beginner
Hello, Ayodeji.
Hello, Ayodeji.
Expressway 8.9 Release notes still says multiple domains are not configurable for MRA,
and I am thinking of using the second pair eff Exp-C/E.
I wonder whether it will work ?
Beginner
Aheem, sorry:
Aheem, sorry:
Unsupported Expressway Features and Limitations When Using MRA
■ Multi-domain and multi-customer support is limited as follows:
— As of X8.5.1, a deployment can have Multiple Presence Domains. This feature is in preview, and we currently recommend that you do not exceed 50 domains.
Enthusiast
Hey Ayodeji
Hey Ayodeji
Are you saying that Expressway Cluster (8.7 and up) on MRA  don't support multiples top level domains using Expressway deployment feature?
For example it will not  support A.com and B.com domain on a single Expressway Cluster. Same for Federation and B2B.
Alex
Content for Community-Ad
August's Community Spotlight Awards
