02-22-2018 01:19 PM - edited 03-17-2019 12:16 PM
Dear all,
I've managed to get the ringlist.xml working for the default tone menu/entry (sorry if the name doesn't fit exactly since I'm using the German locale) via TFTP server.
However if I try to select one of my two configured SIP lines and want to select another ring tone here the phone says that ringlist is not available.
Any idea what I can do?
Do I need to create further ringlist.xml files for each individual SIP line (and if so how should I name them?)?
Thanks for your hints.
Cheers
Blacky42
Solved! Go to Solution.
02-22-2018 01:42 PM
02-22-2018 01:42 PM
02-22-2018 01:58 PM
