12-10-2016 05:56 PM - edited 03-17-2019 08:55 AM
I have 2 brand new BE7Ks installed using version 6 vm and 11.5 cucm. I performed the installation of the first node (publisher) and all went well. I started the installation of the second node and and am unable to pass the communications test. The publisher is synced with an external NTP source. I am not using DNS so under System>Server on the publisher, both the pub and sub server has their IP address in the hostname/IP section. When I put the pubs ip address in the hostname section, it will not accept it. What do I use for host names if there is no dns and I have put ip addresses in the host name section? Will appreciate any help on this. Been at this for a couple days.
Solved! Go to Solution.
12-12-2016 12:36 AM
network cluster attached. Am using the right security password, but I just tried a different password and got the exact same error.
12-11-2016 11:53 AM
Is not mandatory to configure a DNS servers. Only need a NTP server.
The proper check list would be:
-Verify NTP status on PUB "utils ntp status"//check stratum value and status of synchronized or not
- Do ping from the PUB to subscriber "utils network ping x.x.x.x"
Attach all troubleshooting.
12-11-2016 02:17 PM
Alfred,
Thank you for your time and response. I've attached the results of the two commands you asked for. xx.xx.137.10 is the IP of the subscriber. Just so you know what point I'm at, I am still using the installation wizard on the subscriber and am stuck at the screen asking for the hostname and IP for the publisher. This is the communication test that is failing.
12-11-2016 09:31 PM
On the publisher do a utils network eth0 detail and take note of the hostname reported which will be the one you need to specify during subsequent nodes installation.
Carlo
12-11-2016 09:47 PM
Carlo,
utils network eth0 detail is not a command on my console. utils network but there is no eth0 option. I ran the show network eth0 detail and it reported the IP address and some other info but not the hostname.
12-11-2016 09:54 PM
yes sorry for mistyping the command.
Can you please do a show network cluster and post the result here
Thanks a lot
Carlo
12-11-2016 10:07 PM
12-11-2016 10:10 PM
So DBPub is the hostname of the publisher that you have to specify during Subsequent nodes installation.
Carlo
12-11-2016 10:23 PM
Carlo,
I entered that in the wizard and still not working:
Configuration Validation with DBPub failed
Configured first node DBPub is not a first node
12-11-2016 10:37 PM
did you already add the subscriber to the server list?
can you please post a screenshot of the error?
Carlo
12-11-2016 11:30 PM
12-11-2016 11:39 PM
Understand, I've been working some long shifts so sleep is a luxury! I have also tried the USYONG4208CM01 and it gives me the exact same error as the one I posted earlier.
12-11-2016 11:45 PM
From the pub run
utils network ping usyong4208cm01 and see if it correctly resolves the hostname.
Also please post the output of a show status .
Last... did you reboot the server after changing the hostname into ip address?
Please let me know
Carlo
12-11-2016 11:49 PM
I don't think I rebooted the server, I think I only stopped and started the services. Let me get the other commands for you.
12-11-2016 11:53 PM
Please reboot the first node and try to connect again the subscriber to the cluster.
Please let me know
Carlo
