Walkthrough Wednesdays
2412
Slurpas84
Beginner
Can't find SNMP OID from CUCM with snmpwalk
I've read a couple of posts from the forum, describing how to poll ISDN-channels with SNMP.
From thouse posts, I've found out that people use the OID:
1.3.6.1.2.1.10.20.1.2.1.1.2
1.3.6.1.4.1.9.10.19.1.1.4
1.3.6.1.4.1.9.10.19.1.1.1.1.7
My problem is that when i do a SNMP-walk and export the found results, i can't find any of thouse OID:s.
Any help? Am I doing the wrong way or missing something?
(The purpose is to monitor ISDN-activity with SNMP from a 2821 running MGCP with CUCM 8.6.2)
3 REPLIES 3
acampbell
Advocate
May be this link will be of use to you
Getting Channel Usage from a Device
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00801abe59.shtml#topic1
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Thanks for the answer!
The problem thou is that i use snmpwalk for windows and they dont got that kind of syntax.
Here is my output:
C:\>SnmpGet.exe -r:XXX.XXX.XXX.XXX -v:2c -o:1.3.6.1.4.1.9.10.19.1.
1.4
SnmpGet v1.01 - Copyright (C) 2009 SnmpSoft Company
[ More useful network tools on http://www.snmpsoft.com ]
OID=.1.3.6.1.4.1.9.10.19.1.1.4
Type=
Value=
And here is the command-help
Usage:
  SnmpWalk.exe [-q] -r:host [-p:port] [-t:timeout] [-v:version] [-c:community]
        [-ei:engine_id] [-sn:sec_name] [-ap:auth_proto] [-aw:auth_passwd]
        [-pp:priv_proto] [-pw:priv_passwd] [-ce:cont_engine] [-cn:cont_name]
                [-os:start_oid] [-op:stop_oid] [-csv]
   -q               Quiet mode (suppress header; print variable values only).
   -r:host          Name or network address (IPv4/IPv6) of remote host.
   -p:port          SNMP port number on remote host. Default: 161
   -t:timeout       SNMP timeout in seconds (1-600). Default: 5
   -v:version       SNMP version. Supported version: 1, 2c or 3. Default: 1
   -c:community     SNMP community string for SNMP v1/v2c. Default: public
   -ei:engine_id    Engine ID. Format: hexadecimal string. (SNMPv3).
   -sn:sec_name     SNMP security name for SNMPv3.
   -ap:auth_proto   Authentication protocol. Supported: MD5, SHA (SNMPv3).
   -aw:auth_passwd  Authentication password (SNMPv3).
   -pp:priv_proto   Privacy protocol. Supported: DES, IDEA, AES128, AES192,
                    AES256, 3DES (SNMPv3).
   -pw:priv_passwd  Privacy password (SNMPv3).
   -cn:cont_name    Context name. (SNMPv3)
   -ce:cont_engine  Context engine. Format: hexadecimal string. (SNMPv3)
   -os:start_oid    Object ID (OID) of first SNMP variable to walk. Default:.1
   -op:stop_oid     Object ID (OID) of last SNMP variable to walk.
                    Default: walk to the very last variable.
   -csv             Output in CSV (Comma Separated Values) format.
Examples:
  SnmpWalk.exe -r:MainRouter -csv
  SnmpWalk.exe -r:10.0.0.1 -t:10 -c:"admin_rw" -os:.1.3.6.1.2.1.1
  SnmpWalk.exe -r:"::1" -v:3 -sn:SomeName -ap:MD5 -aw:SomeAuthPass -pp:DES
               -pw:SomePrivPass -os:.1.3.6.1.2.1 -op:.1.3.6.1.2.65535 -q
Any sugestions?
(i wanna ensure that i can poll this IOD from a SNMP-program and i first wanna check that it shows a correct info)
abingeor
Can anyone help me in finding engine id details for a dns device
Content for Community-Ad
Spotlight Awards 2021
