2269
Nelsonmejia09
Beginner
Can´t login to 9971 IP Phone via SSH
I Hvae configured in my CUCM the Username and Password about secure shell, but when I try to connect to ip phone using this username and password after the ip phone is reset, I have received a Password authentication failed message. Some advice to fix this issue?
2 REPLIES 2
rajavier
Hello Nelson,
if you have ssh already enabled from phone configuration page, just ssh to the phone and enter you secure shell user and password. Then use login: debug pass: debug.
This should allow you access to ssh on the phone.
-Ramon
Use default/cisco to get a standard shell, use debug/debug  to get the debug shell.
Ronak Patel
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Create
Recognize Your Peers
Content for Community-Ad
