can u format a cisco compact flash card without a cisco router
John Cheetley
Level 3
Level 3
Evening Guys,
Searched forum for answer but couldnt find anything
Want to format a 256 mb cisco CF card. Unfortunately my existing slot0 external slot appears to be dead as the LED for this does not light up
Is there an alternative workaround please
I have a card reader if that can be used....
acampbell
Hi John,
Couple of links for you
http://www.cisco.com/c/en/us/td/docs/routers/access/1800/1841/software/configuration/guide/sw/b_cflash.html#wp49774
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/appendixBcflash.html
In summary
Cisco 18xx  you can use MS-DOS fat 16
Cisco 28xx, 38xx you can use MS-DOS fat 16 or 32
Cisco 19xx ,29xx, 39xx you can use MS-DOS fat 32
Hope this helps
Alex
Regards, Alex. Please rate useful posts.
acampbell
Hi John,
In summary
Hope this helps
Alex
Thanks for your reply acampbell,
That has worked. Much appreciated :)
Insert the flash in a switch and format or any other router.
Thanks Mohammed but I didnt have a spare router :)
