08-18-2010 10:43 AM - edited 03-16-2019 12:19 AM
Hi all,
Is it possible to configure unity for unified messaging where the access to exchange server is through internet(public IP address)?
Bijin
Solved! Go to Solution.
08-18-2010 11:00 AM
As there is no version I'll go with 8.X
•For new installations, a minimum network bandwidth of 100 Mbps between the Cisco Unity server and the following servers:
–The partner Exchange server.
–Any Exchange server on which Cisco Unity subscriber mailboxes are homed.
–The domain controller that Cisco Unity monitors for directory updates.
–The global catalog server that Cisco Unity monitors for directory updates.
–The global catalog server with which the Cisco Unity MAPI client communicates.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/8x/requirements/8xcusysreq.html#wp494986
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-18-2010 11:00 AM
java
08-18-2010 11:08 AM
Hi Java,
Thanks for your answer.
