1933
jobjoseph
Beginner
Can we connect 2N EasyGate GSM gateway using VG224 /FXS/FXO ?
Dear All
Does any one know about 2N GSM gateway integration with CUCM 8X? What I am looking for is the integration using FXO /FXS / VG224 port.
GSM gateway used by Customer which currently connects to Siemens PBX using RJ11:  http://www.2n.cz/en/products/gsm-gateways/analog/easygate/
I have found that there is another GSM gateway from the same company that can be connected to CUCM as a SIP device (http://www.2n.cz/en/products/gsm-gateways/voip/voiceblue-next/) But I am looking for a way to connect the existing
2N® EasyGate analog GSM gateway to CUCM using FXS/FXO/VG224 port.
Many Thanks
Joseph J
1 ACCEPTED SOLUTION
acampbell
Advocate
Hi Joseph
Looking at the box you quoted the interface is :-
Phone interface
  • Type of interface
    2-wire analog. FXS (for phone or CO line of PBX)
This means you will need to use an FXO (2 wire) on the Cisco CUCM side.
I have seen many similar setups in th UK called MOBEX
You will need to create a gateway H323/MGCP where the FXO resides.
You will need to know the access codes/routes and what digits to send to the easygate.
Alex
Regards, Alex. Please rate useful posts.
1 REPLY 1
acampbell
Advocate
Hi Joseph
Phone interface
  • Type of interface
Alex
Create
Recognize Your Peers
Content for Community-Ad
