09-25-2012 03:39 PM - edited 03-16-2019 01:23 PM
Hi Team
I filter users while IpPhone field is different from emptiness, such as the filtering?
! (ipPhone = null)?
Is it more advisable to have the field to zero and let the filter like this:! (ipPhone = 0)?
Thank you
Solved! Go to Solution.
09-26-2012 11:16 AM
A simple and effective filter to use is this..
(ipPhone=*)
This will allow CUCM to import only users with valid entries in their IP phone field. I think its much better
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
09-25-2012 06:31 PM
If this filter works for you it is perfectly fine then, I would not worry about hard coding the field to 0 or anything else that does not make sense.
Chris
09-26-2012 10:54 AM
Hi Chris
I can use the command ldapsearch in the Active Directory for test the filter,
Is it right to the filter : !(ipPhone=null) ?
Thank you
09-26-2012 11:02 AM
Yesenia,
The actual meaning of this filter is this "dont import any user with ipphone field = null"
09-26-2012 11:13 AM
Hi aokanlawon
Then with "null" if I can indicate empty, is that correct?
Thank you
09-26-2012 11:16 AM
(ipPhone=*)
09-26-2012 11:38 AM
Thank you,
I'll be doing tests, I reported how everything went.
