Cisco Community Designated VIP Class of 2020
342
Highlighted
Beginner
Can you disble MLPP Prescendence on CM 7.X on MGCP PRI trunks?
My carrier claims that the Cisco 3845 voice gateway by sending a default prescendce level on the PRI trunks for MLPP is the reason I cannot place outbound calls on my new trunks. Can you even disable this setting? I don't have this problem on other identicle PRI's for the same carrier and they claim the gateway is not sending the prescedence. Any help is much appreciated.
Everyone's tags (8)
2 REPLIES 2
Hall of Fame Cisco Employee
Have you confirmed via some debugs that you're indeed sending some extra data on that PRI vs the ones that are working?
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Could you get the running configuration of a working and non-working gateway. And also, the new trunk is added to existing Route Groups and Route Lists in the CUCM ?
Thnx
Content for Community-Ad
FusionCharts will render here
