Can you use the range command for T1's?
Michael Ricci
I'm trying to reset roughly a few dozen T1's.....This might take a while, is there a range command that I can use similar to the int range command for interfaces?
Aman Soi
Hi Ricci,
I do not think so.
You need to individually enter into controller port and do the shut/no shut or if T1s are coming from a single card of MUX of SP, then, that card could be reset.
regds,
aman
Aman Soi
Hi Ricci,
I do not think so.
regds,
aman
