cancellation IVR & auto attend in cucm 10.5
HI,
i have CUCM ver 10.5 and unity vr 10.5 their is an IVR msg & auto attend i need to cancel them
any help to do that
i try from call management in CUC and call handler and cant cancel it
5 Replies 5
Disable callforwaring to voicemail for AA extension on CUCM.
Response Signature
@Nithin Eluvathingal
the Auto attend work to calls from outside, is this will solve it
your requirement is to cancel the AA am I correct ?
Response Signature
i have 4 FXO line when call any one of them you hear AA message. I need the call go direct to extension without any AA message
you might have configured connection plar pointing to the AA number. remove callforwrding to vm from this extension and assign it to user  phone.
other way is u can change the PLAR configuration to your desired  extension number.
Response Signature
