08-31-2013 06:49 AM - edited 03-16-2019 07:08 PM
Hi All
we have created the following xml file and copied all images to flash but cannot change the background image the phones.
<CiscoIPPhoneImageList>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat640.png" URL="TFTP:Desktops/640x480x24/tharawat640.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/thump.png" URL="TFTP:Desktops/640x480x24/thump.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat95.png" URL="TFTP:Desktops/640x480x24/tharawat95.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/thump23x8.png" URL="TFTP:Desktops/640x480x24/thump23x8.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat320x196.png" URL="TFTP:Desktops/640x480x24/tharawat320x196.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/thump80x49.png" URL="TFTP:Desktops/640x480x24/thump80x49.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat320x212.png" URL="TFTP:Desktops/640x480x24/tharawat320x212.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/thump80x53.png" URL="TFTP:Desktops/640x480x24/thump80x53.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat320x216.png" URL="TFTP:Desktops/640x480x24/tharawat320x216.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/thump80x54.png" URL="TFTP:Desktops/640x480x24/thump80x54.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat800x600.png" URL="TFTP:Desktops/640x480x24/tharawat800x600.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat498x289.png" URL="TFTP:Desktops/640x480x24/tharawat498x289.png"/>
<ImageItem Image="TFTP:Desktops/640x480x24/tharawat234x263.png" URL="TFTP:Desktops/640x480x24/tharawat234x263.png"/>
</CiscoIPPhoneImageList>
getting error the ip phone 8945 "wallpaper cannot be previewed incompatible image size"
could you please update whats the actually image size.
08-31-2013 07:02 AM
Hi All
Sorry i forgot to mention that this is a CME Router 2911.
08-31-2013 07:18 AM
The 99XX & 8961 series documentation is here:
The 8945 series documenation is here:
640 pixels (width) x 480 pixels (height)
123 pixels (width) x 111 pixels (height)
I would first double check and make sure that all TFTP files have been uploaded correctly and have the TFTP service restarted. It looks as if all the phones use the same size of files so you may need to verify what phone firmware you're running. I would upgrade any phone firmware and retest downloading that background images.
Good Luck,
Brad
08-31-2013 07:21 AM
Thanks for the update.
I would verify what version of CME running and check the phone firmware version.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
Good luck,
Brad
08-31-2013 07:26 AM
Hi bradley
Thank you for the replay we have done the configuration that you mentioned above
the 8961 phone firmware is
136 34640640 May 6 2013 13:41:54 +03:00 rootfs8961.9-3-2SR1-1.sebn
137 10728 May 6 2013 13:42:26 +03:00 dkern8961.100609R2-9-3-2SR1-1.sebn
138 1538832 May 6 2013 13:42:54 +03:00 kern8961.9-3-2SR1-1.sebn
139 147256 May 6 2013 13:43:20 +03:00 sboot8961.031610R1-9-3-2SR1-1.sebn
140 1708 May 6 2013 13:43:44 +03:00 sip8961.9-3-2SR1-1.loads
141 67000 May 6 2013 13:44:02 +03:00 skern8961.022809R2-9-3-2SR1-1.sebn
The ios ver
Cisco IOS Software, C2900 Software (C2900-UNIVERSALK9-M), Version 15.3(1)T, RELE ASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 26-Nov-12 14:52 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M15, RELEASE SOFTWARE (fc1)
CME ver
CONFIG (Version=9.1)
Version 9.1
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
08-31-2013 07:33 AM
The version of firmware you're running is unsupported with any versions of CME at this time. What version of IOS is running on the 29XX series router? You need to verify what version of CME you're running and make sure you're running the correct version of firmware for the phones.
It looks like you'll need to downgrade that firmware and re-test.
Brad
08-31-2013 07:36 AM
Hi bradley
The ios ver
CME ver
Version 9.1
