07-13-2012 10:21 PM - edited 03-16-2019 12:11 PM
I have one brand new 2911 router with following IOS. I have changed ios too. Initially there was M4, I have tried M1 and now M but to no vain.
"flash:c2900-universalk9-mz.SPA.151-4.M.bin"
cr2911#sh voice iec description 1.1.186.5.7.5
IEC Version: 1
Entity: 1 (Gateway)
Category: 186 (Signaling socket failure)
Subsystem: 5 (H323)
Error: 7 (Socket error)
Diagnostic Code: 5
07-14-2012 03:21 AM
In other words, what happens ?
07-14-2012 03:41 AM
In other words, Calls are not working on both direction ( inbound & outbound ). Giving busy tone.
07-14-2012 03:45 AM
What is the status of the gateway in cucm? Do you see it as unknow and ip address or unknown unknown. Send your config
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
07-14-2012 03:40 AM
Have you configured the interface to bind h323 signalling to? Can you share your config.
07-14-2012 03:55 AM
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
h323
sip
bind control source-interface Loopback105
bind media source-interface Loopback105
registrar server
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class h323 1
h225 timeout tcp establish 3
voice-card 0
dspfarm
dsp services dspfarm
application
global
service alternate DEFAULT
ip address 10.1.211.193 255.255.255.192
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.1.211.193
voice-port 0/0/0
trunk-group FXO
timing hookflash-out 50
connection plar 2222
caller-id enable
dial-peer voice 10 pots
trunkgroup FXO
tone ringback alert-no-PI
description International
destination-pattern 900.T
fax rate disable
prefix 00
dial-peer voice 7000 voip
preference 1
destination-pattern 1234
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.2.3
dtmf-relay h245-alphanumeric
req-qos guaranteed-delay audio
acc-qos guaranteed-delay audio
fax-relay ecm disable
fax rate 14400
fax nsf 000000
fax protocol pass-through g711ulaw
no vad
dial-peer voice 7002 voip
huntstop
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.50.2.4
fax rate 14400
fax nsf 000000
no vad
07-14-2012 04:00 AM
You are binding sip and h323 to the same interface..I think this is why you are getting socket signalling error
sip
If you want to use h323 then remove the sip binding...
07-14-2012 04:10 AM
but SIP binding is only for IP phone in srst mode. Since i didnt have any sip tunk and sip dialpeer in order to make trunk between CUCM and Gateway.
I am using same config in other gateways too.
07-14-2012 04:13 AM
I suggest you remove it first and see if it works. It is not good to bind different protocol to the same interface. You are telling the gateway to source both h323 and sip signalling from the same interface...
07-14-2012 04:17 AM
Let me change the configuration as you have suggested then i would let you know the result. Thanks
07-14-2012 04:22 AM
That is perfectly fine, nothing prevents a router/gateway to behave like that.
07-14-2012 04:25 AM
Check that addresse matches between GW and CMm and ping with the relecant addresses.
Also for simplicity you can use a physical interface instead of loopback.
07-11-2013 01:28 PM
Did you ever resolve this? We are getting the same thing.
