I have a 504G phone that appears to be stuck in SCCP mode.
I've gone into the menus and tried to factory reset it, but it will not accept the password (pressing OK with a correct password does nothing).
I've tried different firmwares on it, 7.4.7, 7.4.4, etc..
Is there a directive I can put in a configuration file that is being TFTPed to switch it back to SIP?
I believe the problem arose when it was plugged into a network port that autoconfigured its TFTP server.
Thanks.
-- James
