Cannot convert SDP pt=6 to CM payload type
Someone could say what the error "Cannot convert SDP pt=6 to CM payload type" means? What I could to do to solve it?
I am using the Softphone Jitsi registered to CUCM . The call complete, but gives busy signal as soon as I answer.
It's probably a problem with CODEC, but I believe I can do some configuration to solve. Already used the same codec for both endpoints and not solved. I used transcode well.
SDI Annex.
Thanks!
Luciane de Medeiros
2 Accepted Solutions
It looks as if the region between the phones are set to use G729..
09:48:30.709 |RegionsServer::MatchCapabilities -- kbps=8, capACount=6, capBCount=11|*^*^*
Check the Device pool on the phones and ensure the region is set to use G711. You can assign the phones to the same device pool or ensure the region in the device pool is set to use G729.
I am ssuiming that the calling and called phone is  6101084  and 6101099
Please rate useful posts
"For the love of God is broader than the measure of man's mind And the heart of the Eternal is most wonderfully kind"
Please rate all useful posts
From the CUCM trace, we can see CUCM is trying to allocate a xcoder..
09:48:50.430 |MediaTerminationPointControl(19)::getResourcesAllocated -- DeviceName=XD__DF_024 Ci=93105318 ResourceCount=1|4,100,63,1.654^10.222.126.205^*
09:48:50.430 |MediaTerminationPointControl(19)::getResourcesAllocated -- Logging RegionA=REG_MPU_ Caps and MTP/XCoder Region=REG_MPU_ Caps|4,100,63,1.654^10.222.126.205^*
09:48:50.430 |MediaTerminationPointControl(19)::logCapabilitiesinTrace -- MTP/XCoder Device Caps = 4 2 15 16 11 12 257 259 261 |4,100,63,1.654^10.222.126.205^*
09:48:50.430 |MediaTerminationPointControl(19)::logCapabilitiesinTrace -- Device Caps = 25 6 7 8 4 2 15 16 11 12 257 |4,100,63,1.654^10.222.126.205^*
09:48:50.430 |RegionsServer::MatchCapabilities -- kbps=8, capACount=11, capBCount=9|*^*^*
09:48:50.430 |MediaTerminationPointControl(19)::getResourcesAllocated -- Logging RegionB=REG_MPU_CNMP Caps and MTP/XCoder Region=REG_MPU_ Caps|4,100,63,1.654^10.222.126.205^*
09:48:50.430 |MediaTerminationPointControl(19)::logCapabilitiesinTrace -- Device Caps = 6 4 2 86 18 9 |4,100,63,1.654^10.222.126.205^*
09:48:50.430 |RegionsServer::MatchCapabilities -- kbps=8, capACount=6, capBCount=9|*^*^*
09:48:50.430 |MediaTerminationPointControl(19)::getResourcesAllocated -- No matching caps for either side A or side B, MTP not allocated|4,100,63,1.654^10.222.126.205^*
09:48:50.430 |MediaTerminationPointControl(19)::getResourcesAllocated -- match1=4 match2=0|4,100,63,1.654^10.222.126.205^*
09:48:50.430 |MediaTerminationPointControl(19)::getResourcesAllocated -- allocateErrBitset=0x40|4,100,63,1.654^10.222.126.205^*
09:48:50.430 |MediaTerminationPointControl(19)::SendMTPResourceErrToSender - ERROR  AllocateMtpResourceReq failed
Your xcoder =DeviceName=XD__DF_024
The region between your xcoder and the phone invoking the transcoder is set to use G729 also. hence the call fails.
Your scoder has to be set to use G711 between it and the phone trying to use it.
SO I suggesr you put the region between the Jtsi phone and the xcoder to G711. and you can leave the other phone on G729. This way it should work.
7 Replies 7
All,
The problem is really the codec, because the Softphone Jitsi does not support G.729x.
Now I need to create a mechanism for the phones can interoperate. If anyone has any tips or idea I will apreciate.
Luciane de Medeiros
What is the calling and called number. Can you also remove the SDI you posted here. Please paste it to a text file and attach here. Its making the thread very long
Hi aokanlawon.
Sorry!
There are three calls.
The numbers involved are: 6101084 and 6101099.
For the first call:
Calling Number - 6101084
Called Number - 6101099
For the second call:
Calling Number - 6101099
Called Number - 6101084
Thank you!
Luciane de Medeiros
Yes, really. The problem is really the codec, because the Softphone Jitsi does not support G.729x. I tested with G.711 and it worked.
I have transcode (Hardware) registered, but is not being helpful.
Do you have any idea what can I do?
Luciane de Medeiros
Perfect, it worked!
Thank you!
Luciane de Medeiros
