Cannot enter command gatekeeper
eigrpy
Level 4
Level 4
Hi, The gatekeeper is configured in CUCM, but the command gatekeeper cannot be typed under configuration mode in the router 2811.  Anyone can give any comments? Thank you
2 Accepted Solutions
Jaime Valencia
Do you have an IP voice IOS image????
Use the feature navigator for anything related to that
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
java
if this helps, please rate
please, use the following command and post the results:
show version
Note:
1) remember that for 2811 the Gatekeeper feature is supported in Cisco IOS Releases 12.4.15XZ onward.
2) check the following link: CUBE and GK Ordering Guide.
Hope this helps
5 Replies 5
Jaime Valencia
java
Thank you for your reply. You are all very good experts. I have not used this kind of tool yet, but I will learn it. The below is info of the router. Can you take a look at it?
R1#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(4)M7, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Mon 16-Sep-13 00:31 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
R1 uptime is 11 hours, 41 minutes
System restarted at 16:13:35 UTC Wed Dec 30 2015
System image file is "flash:c2800nm-adventerprisek9-mz.151-4.M7.bin"
Last reload type: Normal Reload
try the: c2800nm-adventerprisek9_ivs_li-mz.151-4.M7.bin
Check the following link: 2811 Download Software.
Note: I recommended you to install the 15.1.4M10 release (25/Mar/2015).
Hope this helps
Thank you all. It can work out after upgrading ios. Thank you again!
show version
Note:
Hope this helps
