cannot send dtmf into pstn using h323 SIP Trunk
I have a problem that my IP Phone cannot pass the dtmf, when make a call and need to press 0 1 2 or something like that it doesnt work.
here is the configuration for the dial-peer
dial-peer voice 200 voip
 description ## outgoing all ##
 translation-profile outgoing outgoing-called
 destination-pattern 9T
 session target ipv4:172.16.34.100
 voice-class codec 1
 voice-class h323 1
 dtmf-relay  rtp-nte h245-alphanumeric
 no vad
and when i debug it appear like this
Nov  3 12:32:15.835: //59/B7CEDD9E8088/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x3C
Nov  3 12:32:15.835: //59/B7CEDD9E8088/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
Nov  3 12:32:15.835: //59/B7CEDD9E8088/CCAPI/cc_api_call_digit_end:
Nov  3 12:32:15.835: //59/B7CEDD9E8088/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
Nov  3 12:32:19.579: //59/B7CEDD9E8088/CCAPI/cc_api_call_digit_begin:
Nov  3 12:32:19.579: //59/B7CEDD9E8088/CCAPI/cc_relay_digit_begin_for_3way_conference:
Nov  3 12:32:19.579: //59/B7CEDD9E8088/CCAPI/cc_api_call_digit_end:
Nov  3 12:32:19.579: //59/B7CEDD9E8088/CCAPI/cc_relay_digit_end_for_3way_conference:
Nov  3 12:32:22.251: //59/B7CEDD9E8088/CCAPI/cc_api_call_digit_begin:
Nov  3 12:32:22.251: //59/B7CEDD9E8088/CCAPI/cc_relay_digit_begin_for_3way_conference:
oh yaa.. it ever worked before but i dont know it doesnt work now even though i did not touch the configuration for the dtmf
please help :(
here is the config if needed
Thanks You,
Rocky
7 Replies 7
Ayodeji Okanlawon
What is the call flow. Which destination is the IP phone calling?
Please rate all useful posts
From my Router to the building router here use sip trunk and then from building router to the ISP
172.16.34.100 is building router ip, then i dont know how the building router connect to ISP
Usually use sip trunk.
the dial-peer you posted is h323, I wouldn't make "transcoding" between h323 and SIP. The one you call building-router is most probably a router with a sip trunk to your provider. Here are multiple factors that may cause your issue:
- transcoding between h323 and SIP
- dtmf relay methods mismatch i.e on one router you have h245-alpha and on another rtp-nte
- check what dial-peer are matched for a call when dtmf aren't working.
You should have on both your routers SIP in/out dial-peers like the following.
 incoming called-n 9T
 ses pro sipv2
 voice-class codec 1
! voice-class h323 1
 dtmf-relay  sip-kpml sip-notify
 no vad
------- have a look to my blog lgrconsulting.com
the protocol between my router and the provider is h323 if i changed it into sip i cannot make a call.
is there any possibility ?
thanks,
Rocky
try using h323 and check what dial-peers are matched. show call acti voi comp
lorenz84gDD
it's not clear what you have on the other side of this dial-peer. is it your isp? Maybe something changed on that side...
 voice-class codec 1
 voice-class h323 1
 no vad
so the problem maybe in the other side ?
