Cannot transfer external call to internal extension
kevinshkong11
It is running Cisco CME.
The external call from hunt group cannot transfer to internal extension.
Kindly advise.
Thank you.
6 Replies 6
Suresh Hudda
Dear, Please attach show run & debug voip ccapi inout for a test call.
Suresh
Dear Suresh,
I do not have the debug log at this moment.
Please find the attached for config.
I should say that after the external call from hunt group transfer to internal extension, it cannot transfer to another extension.
Thank you.
Debugs would be useful.
I'm assuming inbound from POTS, PLAR to 200, ext 130, 100 or 103 answers, then transfers to where? What is seen or heard on the phone? What exactly do the press? At what step does the transfer seem to fail? Do any transfers work?
Jesse
Hi Jesse,
Then transfer to other extension, for exp. 108 from PLAR. After that, can it be transferred again?
There is a disconnected tone. I did press transfer button following the extension number.
The call was stopped after transferring again.
Dear, You need to attach 'debug voip ccapi inout' to check whether calling number is getting modified or something else.
Suresh
Dear Suresh,
Please find the attached for debug log.
Thank you.
Kevin
