Cant Change background through common phone profile
Greetings,
I am running 10.x cucm, I modified a background image, I can go to the phone and see it there and change it to the background on the phones. But I need to change it in bulk.  These are 7945G, 7965G phones and the TFTP has the images.  I went to the common phone profile, copied the original, renamed it and then changed the profile.  Enable end users access to background images,,,,, unchecked,  background image "image.pnp" with no paths...... over ride system checked.  Save, bulk edit, run with new phone profile and changes such as the enable end user uncheck do propagate to the phone but the background wont change.  any help would be great.  as I mentioned, I can manually change the phone background on each phone but this needs to be done in bulk.
thank you
8 REPLIES 8
VIP Advisor
are you sure the file name is
are you sure the file name is correct. is it .pnp or .png? Good idea is to take packet capture from the phone and see what files have been requested.
Beginner
Hi Charles,Your problem has a
Beginner
I'm having the exact same
I'm having the exact same problem, but running CUCM 8.5.1.  IP phone 7965G with load SCCP45.9-3-1SR3-1S.  I know it's been a while since the original post. But, any chance you were able to find a solution?
Hi Charles,
Hi Charles,
In the common phone profile configuration, make sure you uncheck  "Enable End User Access to Phone Background Image Setting" and try.
Best Regards,
Sudheer Shenoy
Beginner
Sudheer,
Sudheer,
Charles did mention in his original post that he unchecked that setting. I also did the same. That did not change the end result, which was not being able to apply the new background in bulk, enterprise wide. So far, the only way I have been able to change to the background image is by going to each phone and changing the user settings.  This is not feasible in an environment of thousands of phones.  We need to be able to do this in bulk.
Maybe, as a test,  I would first apply the background image change in the CPP and deploying it, before unchecking the "Enable End User Access to Phone Background Image" setting.  We'll see tomorrow. Any other suggestions would be helpful.
Hall of Fame Cisco Employee
See this enhancement request
Apply background via Common Phone Profile for 79xx phones
CSCud67313
As it has always been, the only option is to script this for those models.
java
if this helps, please rate
Beginner
Hi Jaime, I looked at the bug
Hi Jaime, I looked at the bug you mentioned and it referenced this entry:
https://supportforums.cisco.com/discussion/12573701/7945-phones-not-taking-custom-background-image.
The fix is to update the phones to the latest firmware. After I did that, I was able to push out the new image to the phones in bulk.
Highlighted
Really?? I found a bunch of
Really?? I found a bunch of TAC cases that mentioned they were trying the latest FW  (9.4 something) releases and it just would not work for them, the bug still shows as Open.
I'm glad it worked for you, but it seems that results may vary.
java
Content for Community-Ad
August's Community Spotlight Awards
