cant pull enough power off switch for attendant module to work
jaredap
Hi folks,
Just installed a voip cisco system. I included a few attendant consoles as add ons for my 8851 phones. Unfortunately, the phones are pulling power fine but the one console I have on each phone is not pulling power. I have activated the consoles on the admin software for the phone. Is there a setting on my netgear managed gs752tp switch that may be to blame for not pulling enough power. Any ideas would be greatly appreciated as I prefer not to have to add power supplies to consoles that are supposed to work via poe.
Jaime Valencia
So, you're actually talking about sidecars/KEMs??
If so, see table 4
https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/ip-phone-8800-series-key-expansion-module/datasheet-c78-732356.html
java
if this helps, please rate
yes, this is what I am talking about.  The 8851 should be able to pull enough power from this switch for one KEM but it is not. I am not sure if it is a hardware setting in the switch.
this is the poe status on my switch for the particular phone with KEM that I am speaking of.  The phone with the KEM is on G4 port. Any thoughts?
Interface Admin Mode Priority Level High Power Mode Class Timer
Schedule
Output
Voltage
(Volt)
Output
Current
(mA)
Output
Power
(Watt)
Power
Limit
Status
g1 Enable High 802.3at 0 None 0 0 0 15400 Searching
g2 Enable High 802.3at 3 None 54.8 73 4 15400 DeliveringPower
g3 Enable High 802.3at 0 None 55 63 3.5 15400 DeliveringPower
g4 Enable High 802.3at 3 None 54.8 81 4.4 30000 DeliveringPower
